Floppy ear sun visors
Old Dec 5, 2003 | 06:59 AM
93 ragtop's Avatar
93 ragtop
Default Re: Floppy ear sun visors (tobijohn)
You're probably right but if no one has any feedback on it, for the common good of all C4 owners here I'm willing to order one and check it out....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2446397573
Ya know, looking at that picture, that looks like a piece of a metal venision blind that a lot of people used to hand in windows. (in their home)
[Modified by tobijohn, 4:07 PM 12/4/2003]
Old Dec 7, 2003 | 01:40 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
OK guys, I bought it. I'll let you know how it worked once I get it and have a chance to give it a try...
Old Dec 8, 2003 | 07:41 AM
LT1 Tom's Avatar
LT1 Tom
I installed the $6 ebay piece this weekend. It's a cheap fix but it will work until I decide to replace my sunvisor. It's basically a plastic piece of venetian blind that could probably be duplicated at the hardware store but for $6 why go through the trouble?
Old Dec 8, 2003 | 10:16 AM
LD85's Avatar
LD85
Default Re: Floppy ear sun visors (LT1 Tom)
Flame me now but,,,
I used a wooden paint stir stick,, works very well , just pull the vanity mirror out and slide it in.
AND it lowered my ET 1 full second when I had the top off :lolg: :lolg:
Old Dec 8, 2003 | 07:51 PM
froggy47's Avatar
froggy47
Default Re: Floppy ear sun visors (Rex Ruby)
I guess you could trim up any piece of flexi plastic - tupperware? - and shove/glue it on the floppy end. Does the mirror come off easy? Never checked it out.
Old Dec 8, 2003 | 08:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Floppy ear sun visors (froggy47)
On my '88 the mirror holds the lights & mirror holder to the "masonite" center laminate. The mirror element has two rubber "stoppers" on it's back side that slip through two holes in the "masonite" and keep the mirror in place.
I used a pointed tool to carefully work each rubber stopper back through the "masonite", freeing the mirror element along with the mirror holder & light assembly.
Now I just need to locate the right thickness of cardboard, some plastic strip, some jute padding and the right fabric to do my referbish. :lol:
Old Dec 8, 2003 | 09:25 PM
Strick's Avatar
Strick
Default Re: Floppy ear sun visors (65Z01)
I have the same problem. The first one to come up with a fix has to make a good Tech Tip Article with pictures. :yesnod:
Old Dec 8, 2003 | 09:44 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Floppy ear sun visors (Strick)
I'll give the illustrated Tech Tip a shot once the repair kit I ordered arrives and I have a chance to muck around with it...
Old Dec 8, 2003 | 10:00 PM
Strick's Avatar
Strick
I did a quick cheap fix buy using a plastic coat hanger. I think this flappy design is needed for full use of the visor.
Old Dec 9, 2003 | 01:22 AM
tobijohn's Avatar
tobijohn
Bench Racer
GM should have done what Microsoft DOES: Tell everyone it's a feature and not a design flaw.... ;)
Old Dec 9, 2003 | 01:27 AM
65Z01's Avatar
65Z01
:lol: ....spoken like a true software engineer.... :lol:
Old Dec 13, 2003 | 08:41 PM
tobijohn's Avatar
tobijohn
Bench Racer
Well, I got them and they do work. Both okinawa86vette and 93 ragtop were right, though. The inserts look like a piece of plastic Venetian blind with dimensions of 12"x1.75"x 1/16" which you could pick up and duplicate yourself. With your fingers, you slightly pry up the side of the visor mirror (right side for driver, left side for passenger) and slide it underneath, wiggling it slightly as you feed it in. It's a pretty simple process (i.e. I was able to do it) and it solves the problem. Give me a couple of days to head over to Home Depot to get pricing on comparable material, take a few pics and write this up. In the meantime, if anybody wants a copy of the illustrated instruction sheet, IM or email me and I'll scan and send it off to you...
[Modified by tobijohn, 2:31 AM 12/14/2003]
Old Dec 14, 2003 | 12:58 PM
  #33
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Floppy ear sun visors (gybonz)
Had my 87's redone for $45.00 for the set... and they look better than new, and a heck of a lot cheaper, that for sure...
Martin Hernandez [stichinproducts@msn.com]
you just send him your visors and they come back like new... :thumbs: :thumbs:
Old Dec 14, 2003 | 01:32 PM
  #34
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Floppy ear sun visors (vinnies87)
Good to know if I REALLY get ****. Does he have a web site?
Old Dec 14, 2003 | 01:40 PM
  #35
65Z01's Avatar
65Z01
vinnies87, does that include new cardboard to fix the broken ears or were your's only in need of recovering?
Old Dec 14, 2003 | 02:47 PM
  #36
BowTieBlood's Avatar
BowTieBlood
tobijohn:
I'd like to see a scanned in version of the install sheet, try and do it myself with stuff around the house.... BowTieBloodC4@AOL.com :cheers: Thanks ahead of time.
Old Dec 14, 2003 | 02:51 PM
  #37
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Floppy ear sun visors (BowTieBlood)
On the way...
Old Dec 14, 2003 | 04:41 PM
  #38
froggy47's Avatar
froggy47
Hi Tobi,
Any chance I could get those instructions too?
bobplante@adelphia.net
Thanks if you can. :)
Old Dec 14, 2003 | 04:45 PM
  #39
tobijohn's Avatar
tobijohn
Bench Racer
Done! Check your email...
