Is the windage tray necessary?
Old Dec 4, 2003 | 12:24 AM
kman0066's Avatar
kman0066
Default Is the windage tray necessary?
Well, in the middle of my engine build I am faced with yet another question. I am planning on getting the oil pan that TPIS sells which says it includes a built in windage tray. Does this mean I don't have to put in the mangled piece of metal that was once considered my stock LT1 windage tray(pre-detonation era term). It's a little late, considering I already have the mains machined to use some studs that are not long enough to use the stock windage tray, but I thought I'd ask anyways.
Old Dec 4, 2003 | 05:20 PM
SPEED750's Avatar
SPEED750
Default Re: Is the windage tray necessary? (kman0066)
You should be ok with just the tpis tray.You can't use both. :chevy
Old Dec 4, 2003 | 05:30 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
If your pan has an integral windage tray you should be more than fine.
To Is the windage tray necessary?
