Tire size QUESTIONS??
Old Dec 4, 2003 | 03:08 AM
vettespd20's Avatar
vettespd20
Default Tire size QUESTIONS??
I am kind of lost on tire sizes, my friend keeps confusing me. Ok the first number is basically the lenth of the tire and the second number is lower the number is the wider it is right?? For instance i have 2 sets of tires, a set of 255-50-zr16 and a set of 275-40- zr 17 so the 17 rims with tires should be wider but they look the same some one help me i am confused i know there is a technical way of knowing but i want to get rid of the mumbo jumbo and just know the basics lol thanks :steering:
Old Dec 4, 2003 | 07:58 AM
HTRK-1's Avatar
HTRK-1
Default Re: Tire size QUESTIONS?? (vettespd20)
Check here. :cheers: http://www.tirerack.com/tires/tiretech/general/size.htm
Old Dec 4, 2003 | 09:49 AM
vader86's Avatar
vader86
First number is the width of the tire, second is sidewall height
You should use 275s or 285s on a 9.5" rim, 245s or 255s on a 8.5"
Old Dec 4, 2003 | 09:55 AM
96CollectorSport's Avatar
96CollectorSport
From: If you don't weigh in you don't wrestle Road America
Default Re: Tire size QUESTIONS?? (vader86)
The first number is width in mm, the second number is what is called the aspect ratio, a percentage of the width. So if you have a 275/40/17 you would take 40% of 275mm so 275x.4 = 110mm the height of your side wall, the last number obviously is the rim diameter. :thumbs:
Old Dec 4, 2003 | 11:25 AM
NeedSpeed's Avatar
NeedSpeed
Default Re: Tire size QUESTIONS?? (96CollectorSport)
:withstupid:
Don't you love the mixed english / metric system? :rolleyes:
Old Dec 4, 2003 | 04:34 PM
vettespd20's Avatar
vettespd20
Default Re: Tire size QUESTIONS?? (NeedSpeed)
So 275 means that they are pretty wide right?? And if the 40 means how much rubber from the of the tire to the rims right, and if its a 40 that is why its kinda low profile right??
Old Dec 4, 2003 | 05:12 PM
NeedSpeed's Avatar
NeedSpeed
Yes, 275 is the width in millimeters. So since, 1in = 2.54cm,
275mm = 27.5cm and 27.5/2.54 = 10.8in, the width in inches.
Now 40 is related to the sidewall height, and in general a lower number means a lower profile. But, since it is a ratio of the height and width, a tire that is say 205/40 will have a different sidewall height than the 275/40.
[Modified by NeedSpeed, 4:14 PM 12/4/2003]
To Tire size QUESTIONS??
