84 TRW pistons.
Old Dec 6, 2003 | 01:13 PM
devilfish's Avatar
devilfish
Default 84 TRW pistons.
How much stronger are they then the stock pistons 86-96?
Is it worth to swap them with my 91 stock pistons? I got 8 for free by a friend.
Can they handel a blower?
Old Dec 6, 2003 | 03:31 PM
devilfish's Avatar
devilfish
Default Re: 84 TRW pistons. (devilfish)
comon guys...
Old Dec 6, 2003 | 03:52 PM
lead foot 85 vet's Avatar
lead foot 85 vet
the 84 came with forged pistons...depending on the mileage on then they are better than 91 pistons. :cheers:
Old Dec 6, 2003 | 03:59 PM
MrNuke's Avatar
MrNuke
Simply put...... WAAAAAaaaayyy stronger... :yesnod:
Old Dec 6, 2003 | 05:13 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I always thought that the '84 pistons were cast. Learn something new everyday.
Right?
4 Bolt main also?
thanks
tony
:flag
Old Dec 7, 2003 | 06:14 AM
devilfish's Avatar
devilfish
Default Re: 84 TRW pistons. (oldace84)
so with a set of 84 pistons new rods and ARP bolts everywhere. And the comp arou9.9:1, you should be abel to handel a superscharger?
Old Dec 7, 2003 | 09:30 AM
No Go's Avatar
No Go
Used pistons???
Waste of time compared to what you have to do to do it.
New pistons are only ~200 bucks.
:confused:
Old Dec 7, 2003 | 02:22 PM
devilfish's Avatar
devilfish
Default Re: 84 TRW pistons. (No Go)
yeh well not "over here".. And they have ben in a engine that have gone 9000km.
ANd If they look good I can use the maoney i saved to get forged rods..
Old Dec 7, 2003 | 03:51 PM
Curveit's Avatar
Curveit
You should have the cylinders lightly honed. Then the pistons, and cylinders should be measured with a micrometer to check the clearances. I'm not sure if a blower motor has different specifications for piston-to-wall clearances, but I know the rings have certain gaps for blowers, and NOS. The pistons should also weigh about the same, or you will need to re-balance the crank. Good luck, and I hope this helps some.
:chevy
Old Dec 7, 2003 | 05:18 PM
devilfish's Avatar
devilfish
Default Re: 84 TRW pistons. (Curveit)
thank you..
I will internal balance the engine anyway..
To 84 TRW pistons.
