I just changed my front spring. The key: the car has to be VERY high to get the spring in and out. I used a Walker 2 ton floor jack and it barely got the car high enough to get the springs in and out.
It should only take about an hour to do the rear, just remove the catback, spare tire and the two endlinks for the spring, then the four bolts that hold it to the rear end.
The fronts gonna require you doing some digging into the suspension. Just take your time and unbolt things one at a time. I would have some jackstands and a really, really tall floor jack or a lift to do it. Because of the curve of the spring, it's gonna take a lot of ground clearance to do.
