92 INTERIOR LIGHT GLITCH
Old Dec 8, 2003 | 07:07 PM
mjfox's Avatar
mjfox
Default 92 INTERIOR LIGHT GLITCH
When I turn into a driveway sideways are in anyway as if the car is on a slant the interior lights will come on
anyone had this problem
is my car twisting as it enters the driveway and the door ajar switch is disconnecting??????????????????????????? ???????????????
thanks mike
Old Dec 8, 2003 | 07:13 PM
6spd's Avatar
6spd
Default Re: 92 INTERIOR LIGHT GLITCH (mjfox)
i had the same problem with my 91 you are correct the switch is seperating when you go on a slant. i replaced both switches rather than rig it up with tape or gum like some people i know.
Old Dec 8, 2003 | 09:00 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Check the hatch switch as well. This happened to me, I'm going on my thrid hatch switch. As a temporary measure, I've unplugged the hatch switch, it has no effect on the alarm. I bought a replacement door switch and it didn't fix the problem, maybe yours will.
Old Dec 8, 2003 | 09:30 PM
Mangusta1969's Avatar
Mangusta1969
Default Re: 92 INTERIOR LIGHT GLITCH (Mr Mojo)
My 91 convertible (flexible flyer) does this, too, on angled driveways and sometimes on hard left turns.
I guess it could be the convertible hatch mechanism; I will have to check if popping that open also gives a door ajar signal.
However, it looks like the alignment of the door ajar switches is a little off, as verified by a small dot of grease in the center of the door ajar switch. Since the doors line up correctly in the vertical and horizontal and are closing correctly, I guess I will have to resort to some sort of shim material on the little black body buttons. What are others using that doesn't look too bad?
Old Dec 9, 2003 | 12:31 AM
Bodhi's Avatar
Bodhi
You need one or more of these:
http://www.ecklers.com/product.asp?p...1LUG3LD1XP986B
My Vette has had 8 door ajar sensors.....they are cheap plastic JUNK (thanks GM :mad ) The dealership replaced 4 in one day on my Vette....3 were bad from GM :smash:
To 92 INTERIOR LIGHT GLITCH
