spark plug reading.
Old Dec 9, 2003 | 05:21 PM
devilfish's Avatar
devilfish
Default spark plug reading.
all my plugs looked good exept no7. It whas black. I dont think its oil, cause its not "sticky" more like black "paint", or dark dark brown paint. You cant rub it off with your fingers.
Could that be a leaky injector? Or does oil behave like this aswell?
Oh and the car eats no oil whatsoever, or at least what I can see..
Old Dec 9, 2003 | 06:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: spark plug reading. (devilfish)
That sounds like a good possibility; is fuel pressure holding at the fuel rail?
Old Dec 11, 2003 | 01:40 AM
devilfish's Avatar
devilfish
Default Re: spark plug reading. (65Z01)
fuel pressure holds only about 2 days, then you have zero presure att the rail..
Normal?
Old Dec 11, 2003 | 02:20 AM
65Z01's Avatar
65Z01
Two day sounds fine for total bleed down.
Do they hold high pressure for a while after you shut off the engine or leak quickly to some low pressure?
Old Dec 11, 2003 | 04:12 AM
devilfish's Avatar
devilfish
got to check that today. I keep you posted...
thanks
To spark plug reading.
