Hard to get in gear..
Old Dec 11, 2003 | 10:02 AM
devilfish's Avatar
devilfish
Default Hard to get in gear..
..sometimes with my Zf gear box. I changed the fluid.
If I "pump" the clutch it gets better. Sounds like a bad slave or main cylinder?
Old Dec 11, 2003 | 12:01 PM
jfb's Avatar
jfb
Default Re: Hard to get in gear.. (devilfish)
Check for low clutch fluid, if ok, its time for either or both master and slave.
Old Dec 11, 2003 | 12:27 PM
rick lambert's Avatar
rick lambert
Default Re: Hard to get in gear.. (jfb)
Is it possible you have air in the system? maybe it just need bleeding. :rolleyes:
Old Dec 11, 2003 | 06:18 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Definately a problem with the master/slave. Bleed it real good and try it again. What is happening is the clutch is not fully releasing causing drag in the clutch which in turn is causing the hard shifting.
Old Dec 12, 2003 | 03:04 AM
devilfish's Avatar
devilfish
Default Re: Hard to get in gear.. (Vette92)
hmm can you tell if it is the slave or master? Any "test" you can do?
Old Dec 12, 2003 | 09:32 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Best thing to do would be bleed it with fresh fluid to get all of the old stuff out. Wehn you are bleeding it, check for leaks coming from the end of the slave (where the fluid would be going into the bellhousing). At the same time, you may want to feel up under the pedal where the master's pushrod comes in through the firewall and check for any signs of fluid there.
Sounds like one of them is leaking which is leaving your fluid level low. Bleeding it should cure the problem short term if so.
Chris
To Hard to get in gear..
