Slave Cylinder Bleeding
Old Dec 11, 2003 | 02:07 PM
myblack864+3's Avatar
myblack864+3
Default Slave Cylinder Bleeding
I just replaced the clutch master and slave cylinder on my 86 and I can't seem to get a good bleed job. Any tips out there for doing this either 1) easy or 2) right. :crazy:
Many Thanks.
Old Dec 11, 2003 | 02:21 PM
STL94LT1's Avatar
STL94LT1
Default Re: Slave Cylinder Bleeding (myblack864+3)
Remove the slave cylinder from the bellhousing, rotate the slave so the bleed screw is at the top, then bleed the system. This will keep air from being trapped in the top of the slave.
Old Dec 12, 2003 | 11:40 AM
FullShred's Avatar
FullShred
I tried doing it by the book, but still couldn't get all the air out. I wound up using The Green Rocket's procedure here:
http://forums.corvetteforum.com/zerothread?id=331080
Works good.
To Slave Cylinder Bleeding
