shifter movement?
Old Dec 12, 2003 | 01:30 AM
Clemson Vette's Avatar
Clemson Vette
Default shifter movement?
i just noticed this week that if i keep my car in a low gear then stab the gas, the shifter moves alot. like maybe a half inch to an inch of play straight up. has it always done this? are my bushings gone? does it need fixing? do your guy's cars do this? thanks for the help.
Old Dec 12, 2003 | 01:49 AM
JordiZR1's Avatar
JordiZR1
Default Re: shifter movement? (Clemson Vette)
If you are talking about a manual 6 speed you have to retorque the front bolts in the c-beam, those are 2 bolts that attach the c-beam to the rear of the ZF, they tend to come loose. It is a common problem with an easy fix.
Old Dec 12, 2003 | 01:50 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: shifter movement? (JordiZR1)
:withstupid:
Get a set of beam plates as well.
To shifter movement?
