Hot starts
Old Dec 14, 2003 | 01:40 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default Hot starts
Car is having a hard time starting after its been sitting for about 10 minutes after being fully warmed up. Its a brand new 383 stroker with new everything from gears to injectors (ford svo). When its cold it cranks right up. When its warm it always stumbles for about 5 seconds before it smooths out. Almost like the fuels not getting to the injectors. It has a brand new fuel pump and new fuel filter. I had a custom burned chip from Ed Wright because I eliminated the 9th injector. Some said my fuel is getting hot and turning to vapor and I need to increase the fuel pressure. :crazy:
Old Dec 14, 2003 | 10:07 AM
86VetteBill's Avatar
86VetteBill
Default Re: Hot starts (PMARTINEZ92126)
Just a guess, but is there a chance of leaking injectors which might create a 'flooded' environment? YOu might want to put a fuel pressure gauge on there and see what happens after you turn off the car. If it goes down, there's your problem.
