emergency brake cable
Old Dec 14, 2003 | 07:45 PM
86 silver bullit's Avatar
86 silver bullit
Default emergency brake cable
any ideas on hooking up emergency brake cable the has came off the passanger side rear wheel...It almost goes back on but just about a 1/4 " away..any tricks I should try before I dissmantle the rear brakes ...thanks..
Old Dec 14, 2003 | 09:17 PM
AEmedic's Avatar
AEmedic
Default Re: emergency brake cable (86 silver bullit)
I think if you dismount the e-brake handle assembly you should have enough play.
Old Dec 15, 2003 | 10:18 PM
86 silver bullit
Default Re: emergency brake cable (AEmedic)
Thanks..but I did get it back on..I just bent the e brake mount near the rear wheel enough to slip the eye on the post..the positioned the bracket back to were it was...Car is finally back on the ground... :chevy
To emergency brake cable
