From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Re: Ball joint/Tie rod end questions. (xs650)
Sounds like we're both doing simular mods. I found a local parts shop that will sell me all Moog parts. He is a CarQuest dealer and has some good discounts to offer.
Re: Ball joint/Tie rod end questions. (JrRifleCoach)
I bought MOOG components from http://www.rockauto.com good prices and reasonable shipping. Used a arbor press to put in the new lowers. Uppers are fairly easy using a grinder and a center punch.
Consider getting your uppers from Corvette Central. Was a thread a while ago about them only costing $99 each. Bad thing is rubber bushings, but unless you race/autocross, stick with rubber.
Could have been me. I've been watching about three other threads on the subject. I ordered a complete ES (graphite) kit plus front/rear anti-roll bar kits from Summit today. Totaled out at around $225. They had the main kit in stock and the bar kits are special order.
Make sure you measure your bars and not depend on the equipment lists. I have a 26mm front and 24mm rear. That combo does not show in the lists that I referenced.
