plastiguage???
Old Dec 16, 2003 | 07:51 AM
premiervette's Avatar
premiervette
Default plastiguage???
i heard that you should use plastigauge for the connecting rods to check for clearances but how do you use it? what do you do? certain procedure? :confused:
Old Dec 16, 2003 | 08:29 AM
sraft's Avatar
sraft
Default Re: plastiguage??? (premiervette)
Remove rod bearing cap and insert a strip of plastiguage across the bearing. Reinstall cap and torque down. Remove cap and you'll see that the plastiguage has flattened out. The tighter the clearance, the wider the plastiguage gets. The kit comes with a printed gauge to compare against the flattened strip - just match up the width and it tells you the clearance.
Old Dec 16, 2003 | 08:30 AM
JackDidley's Avatar
JackDidley
Good stuff. Cut a strip, lay it across the bearing surface on the crank, torque down the bearing cap and then remove it. Compare the smashed bit on the crank with the sample on the pack, and you have a reading. Clean it off before assemby. :chevy
Old Dec 16, 2003 | 09:27 AM
OleDog's Avatar
OleDog
Great Question, good answers. But.........you do this when? Cold, warm, hot?
Old Dec 16, 2003 | 09:35 AM
C10 JDR's Avatar
C10 JDR
Default Re: plastiguage??? (OleDog)
Cold :)
Old Dec 16, 2003 | 02:07 PM
1989redvette's Avatar
1989redvette
you do it when your first putting a motor together and the bearings have to be dry as in no oil to get a good reading...using mics and caliopers is a far better way to check this... put plastigaauge will work for a grocery getter motor...it is a very crude way of checking a very important clearance :skep:
Old Dec 16, 2003 | 02:58 PM
corvettemaster's Avatar
corvettemaster
good to hear somone is actually putting a motor back together the correct way :crazy: around here people just throw em together and don't measure nothing :eek:
anyways, i always use the green plastiguage. i find it works best. you can use it to check clearances for the rods, crankshaft, etc. an easy way to get it off afterwards is to use a little clean motor oil on a lint free rag. it'll wipe it right off. :cheers:
Old Dec 16, 2003 | 03:04 PM
scorp508's Avatar
scorp508
Default Re: plastiguage??? (corvettemaster)
I used plastigauge on my current engine's rod & main bearings. Good stuff. :thumbs: Just make sure you use some relatively new stuff. When it gets old it gets brittle and will just sorta turn into powder instead of flattening out.
Old Dec 16, 2003 | 04:38 PM
xs650's Avatar
xs650
Default Re: plastiguage??? (1989redvette)
you do it when your first putting a motor together and the bearings have to be dry as in no oil to get a good reading...using mics and caliopers is a far better way to check this... put plastigaauge will work for a grocery getter motor...it is a very crude way of checking a very important clearance.
:skep:
Calipers better than plasti gauge?
Even using proper equipment, I doubt that the average home engine builder would get more accurate results by measuring the parts and subtracting the difference to get clearance.
Better to measure the clearance directly (Plasti gauge) unless you have the proper measuring equipment and experiance in using it.
[Modified by xs650, 1:42 PM 12/16/2003]
Old Dec 17, 2003 | 12:42 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: plastiguage??? (xs650)
Plastiiguage comes in different thicknesses. The real thinn stuff for connecting rod bearings and thicker stuff for mains. Just make sure that the stuff that you purchase covers the range of bearing clearances that you are trying to read!
It a very good secong check to make sure the machine shop was NOT asleep at the machine!
BC :thumbs:
To plastiguage???
