Traceing down a .5 amp draw...
Old Dec 16, 2003 | 05:08 PM
david85's Avatar
david85
Default Traceing down a .5 amp draw...
Well, I figured out the steering column problem, and now wish to continue the original problem. If I leave the battery connected, it will go dead overnight. I put a amp meter between the disconnected positive battery cable, and the positive post on the battery, and read a .5 map draw. Is this the proper way to trace this? I've also pulled all the fuses and still have the same problem.... Any other ideas?
Old Dec 16, 2003 | 05:28 PM
LD85's Avatar
LD85
Default Re: Traceing down a .5 amp draw... (david85)
On my 85 I had two wires touching on the power side of the the Fuel Pump Relay or the OD relay on the fire wall I dont recall which relay it was,
the connector wires are stripped back so far that they touched and would draw my battery down and make my lights DING if I ws driving and turned them on.
Sorry I cant help more but you could check them out.
Old Dec 16, 2003 | 05:29 PM
85blkZ51's Avatar
85blkZ51
Were you pulling one fuse at a time and then checking the meter?
Old Dec 16, 2003 | 05:38 PM
david85's Avatar
david85
Default Re: Traceing down a .5 amp draw... (85blkZ51)
Yes, I pulled each fuse and checked the meter.
Old Dec 16, 2003 | 05:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There are several fusable links from the battery but unfortunately my old '85 shop manual doesn't include the electrical suppliment volume.
While measuring leakage current, recheck that all lights are off and that the alarm system is not armed.
You may need to disconnect some of the fusable links from the terminal block behind the battery.
Try disconnecting the alternator, just for laughs & giggles.
Old Dec 16, 2003 | 05:50 PM
Beth396's Avatar
Beth396
This is a hassel because you have to get under the car. Disconnect the fat 12V line to the selenoid/starter. If your selenoid windings are going (shorted between turns) you'll start drawing current. You should be around 200/20 mA in awake/sleep mode. Just something to try. I just went through this.
Old Dec 16, 2003 | 06:03 PM
xs650's Avatar
xs650
Sounds like a good approach to finding the problem. Did you possibly miss any fuses like the oddball ones hidden in the engine compartment?
Dick
Old Dec 16, 2003 | 06:10 PM
85blkZ51's Avatar
85blkZ51
Does the console light go out when the lid is closed?
Old Dec 16, 2003 | 06:50 PM
Ramrod92's Avatar
Ramrod92
It should. I believe there is a mercury switch in the lid.
Old Dec 16, 2003 | 06:54 PM
Mangusta1969's Avatar
Mangusta1969
You can easily determine the current draw for the glove compartment light and center console lights. Just turn each of these lights on separately and note what the current reading is. If it is close to .5amps you may have the culprit.
I have not experienced this, but someone posted recently that one of the car's computers can get "stuck" in an above normal current draw mode and will rapidly drain the battery. In their posting, they said that this "stuck" mode would stop if you disconnected the battery and then re-connected it. I suspect you have already tried this if you are already using your ammeter to troubleshoot.
20 milliamps is exactly what my 91 convertible draws after the courtesy lights go out and the security system goes into sleep mode.
The tip on disconnecting the alternator from the soup is a good one. If you have a diode going bad, it can drain the battery by allowing current to flow in the wrong direction. Be sure to let us know what you find. I am going to file that starter motor windings problem note above away for future reference!
Old Dec 16, 2003 | 07:31 PM
red-y's Avatar
red-y
Default Re: Traceing down a .5 amp draw... (Mangusta1969)
I had the positive post touching the frame. :skep:
Old Dec 17, 2003 | 12:31 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My bet is the alternator!!! Please keep us posted! Interesting problem!
BC
Old Dec 17, 2003 | 12:34 AM
xs650's Avatar
xs650
Default Re: Traceing down a .5 amp draw... (Bill Curlee)
BC
:iagree:
I've see old diodes get leaky.
Old Dec 17, 2003 | 08:14 AM
david85's Avatar
david85
Default Re: Traceing down a .5 amp draw... (xs650)
Well, I tried the alternator with no help. Since buying the car, none of the interior/console lights have worked. It looks like my next try will be the fuseable links by the starter/firewall?
Old Dec 17, 2003 | 12:12 PM
jfb's Avatar
jfb
At night check for the underhood lights, the map compartment light, the courtesy lights, mirror lights, all external car lights. Do you have any electrical accessories? like a radar detector, aftermarket audio amplifier or radio ? Check em. Forum members have found seat adjust switches stuck on and start solenoid switches leaking current (remove the cable going to the starter after first disconnecting the positive battery cable). Good luck.
Old Dec 17, 2003 | 12:18 PM
xs650's Avatar
xs650
Default Re: Traceing down a .5 amp draw... (jfb)
At night check for the underhood lights, .
Corvette underhood lights must put on a nice light show when you get on the brakes just right on arough road :jester
Another way to check underhood and such lights is to open the hood while watching the ammeter. If the current doesn't increase, you know the light was already on.
Dick
Old Dec 17, 2003 | 08:49 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Not sure which circuit the vanity mirror and console light are on, you might want to check these.
:cheers:
To Traceing down a .5 amp draw...
Old Dec 17, 2003 | 08:53 PM
JrRifleCoach
Not sure which circuit the passenger's vanity mirror is on, you might want to check.
:cheers:
Old Dec 17, 2003 | 09:03 PM
69vetteracer's Avatar
69vetteracer
If none of your interior lights have worked you probably have a shorted interior light controller. :chevy
Old Dec 17, 2003 | 09:17 PM
TheStef's Avatar
TheStef
Default Re: Traceing down a .5 amp draw... (69vetteracer)
I have an after market alarm system, the ones that make a lot of noise when you forget to disarm them before opening the door. :D
Anyway's my battery goes dead after about 2 weeks if I let the car sit without being started, I'm guessing this is because of my after market alarm system.
Just trying to give some ideas
good luck
