Tranny guys, quick question
Old Dec 20, 2003 | 10:22 AM
Brimis's Avatar
Brimis
Default Tranny guys, quick question
84 in driveway with trans pan off, removed filter grommet that was stuck in housing. About to install filter and gasket. Will torque accordingly.
I bought a fluid called Lucas which helps slipping, would you add it to fluid.
[Modified by Brimis, 1:56 PM 12/20/2003]
Old Dec 20, 2003 | 11:21 AM
bogus's Avatar
bogus
Default Re: Tranny guys, quick question (Brimis)
when doing a tranny tune up, you never get all the fluid out. about 1/2 of the volume is still in the torque converter... sucks, eh?
Old Dec 21, 2003 | 07:47 AM
NoWorries's Avatar
NoWorries
Make sure you get the old seal out of the filter hole, I've only done seven tranny's to date, but everone of them had a stuck grommet.
I don't know about adding anything to the fluid, probably couldn't hurt, but I don't think it's going to make much of a difference.
Old Dec 21, 2003 | 09:02 AM
Brimis's Avatar
Brimis
The old seal was stuck in the housing, I carefully removed it and installed the new filter. One of the 13 mm housing holes is striped which is way the previous owner had a longer 13 mm bolt up in there. I'm not leaking any fluid, but will tap the hole to the next larger size.
The fluid change appeared to have fixed the slip I was getting at 40 mph.
I'm hoping the problem was the filter, although the fluid looked okay the filter was dirty.
[Modified by Brimis, 9:06 AM 12/21/2003]
To Tranny guys, quick question
