spark plugs
Dec 20, 2003 | 03:39 PM
spark plugs
What is the best plug to use .......Bosch Platinum or AC Delco
Dec 20, 2003 | 03:42 PM
Re: spark plugs (darkred91)
I use the AC Delco Rapidfires
Dec 20, 2003 | 03:47 PM
NGK TR55IX
Dec 20, 2003 | 04:10 PM
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
It depends on your needs. If you have a mostly stock car, or even slightly modified, good old ACDelcos or Champions will do just fine. IMHO, let the flaming begin :rolleyes: , all those special plugs with two, three, and four electrodes aren't worth the dough. I've not seen back to back dyno runs comparing each, but my gut feeling is that you're not going to see a difference, no matter what their marketing departments tell you.
The Bosch Platinums, if you do a ton of driving, can offer a benefit, because they'll last longer. This is great if you're like me and don't like struggling with the plugs on a regular basis (30K or so). Put the Platinums in, and you're good for another 100K.
:cheers:
Dec 20, 2003 | 05:20 PM
Re: spark plugs (Strick)
Thats what I have :yesnod:
Dec 20, 2003 | 05:28 PM
I like the Denso Iridiums. But, they are a bit expensive.
Dec 20, 2003 | 06:22 PM
Re: spark plugs (STL94LT1)
Rapid fires for me! :steering:
Dec 20, 2003 | 06:41 PM
Re: spark plugs (MaddMaxx)
I've always wondered.....
What is the life expenctancy of the Iridium plugs. I can't seem to justify changing plugs that cost that much every 30k miles.
Just wondering.... :confused:
Dec 21, 2003 | 12:47 AM
Re: spark plugs (vader86)
:iagree:
Rapidfire's here also.
Dec 21, 2003 | 01:48 AM
I use NGK FR5.
Dec 22, 2003 | 09:44 AM
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I use NGK V-Power plugs in my '85. No problems! :yesnod:
Dec 22, 2003 | 10:20 AM
Re: spark plugs (H P Bushrod)
AC Delco Rapid Fires #5.
Dec 22, 2003 | 12:34 PM
I use NGK TR6's they're copper and work well with Nitrous and they only cost $12.00 a set at O'Reilly's. [IMG][/IMG] :rant:
Dec 22, 2003 | 01:21 PM
Dec 22, 2003 | 08:31 PM
I use the Bosch Platium 4 plugs in my 86... :party:
Dec 23, 2003 | 06:51 AM
Re: spark plugs (darkman5001)
AC Delco's are what I have RIGHT NOW> but I LIKE the bosch platinums, the double pronged version preferably please.
Dec 23, 2003 | 02:16 PM
NGK FR-5 :flag
