HELP! engine sputter/miss
Old Dec 20, 2003 | 04:52 PM
sdaztecs's Avatar
sdaztecs
Cruising
Default HELP! engine sputter/miss
Help, I'm at a loss. I have a 1991 coupe, 6 speed. The car has Trick Flow heads, oversized runners, a 58mm Throttle Body and a hypertech chip. This problem is new. The car runs great when it is cold. It idles great and has a ton of power through the RPM range. After it gets warm it still idles fine, but under load it misses or surges. A definite loss of power. I've changed the plugs, wires, cap and rotor, and cleaned teh injectors. Any advice would be appreciated. Thanks
Old Dec 20, 2003 | 04:57 PM
STL94LT1's Avatar
STL94LT1
Default Re: HELP! engine sputter/miss (sdaztecs)
It may be an o2 sensor. Sounds like it starts running poorly when it goes into closed loop.
Old Dec 20, 2003 | 04:58 PM
sdaztecs's Avatar
sdaztecs
Cruising
I forgot to add the coputer shows no codes. Thanks again
Old Dec 20, 2003 | 06:54 PM
bogus's Avatar
bogus
could be the fuel pump.
Old Dec 21, 2003 | 10:05 AM
Mark-44's Avatar
Mark-44
Default Re: HELP! engine sputter/miss (bogus)
If its not low on fuel, I would suspect the fuel pump.
(1). Fill the tank
(2). Fuel filter
(3). Fuel pump relay
(4). Fuel pump
To HELP! engine sputter/miss
