L98 block over bore max?
Old Dec 21, 2003 | 09:49 PM
Formula 94 LT1's Avatar
Formula 94 LT1
Default L98 block over bore max?
I saw lingenfelter made an "L98" with Afr heads and super ram intake, but was unsure if the block actually was originally an L98 block because the bore was 4.155".... they apparently overbored the lt1 block .100" so maybe the L98 block was a little thicker??
Old Dec 21, 2003 | 09:57 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: L98 block over bore max? (Formula 94 LT1)
it was a bowtie 400 base block :cheers:
Old Dec 21, 2003 | 11:02 PM
vader86's Avatar
vader86
I dont know if youre allowed to bore the stock 350 block more than .060"
Old Dec 22, 2003 | 01:56 AM
mistaben's Avatar
mistaben
Default Re: L98 block over bore max? (vader86)
can you have heating problems at .040? or when do they begin in reality?
Old Dec 22, 2003 | 01:22 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: L98 block over bore max? (mistaben)
It varies from block to block. When the block is cast, the cylinders are located by a sand core. "Core shift" can result in different cylinder wall thickness. The block can be "sonic tested" for wall thickness. I wouldn't be comfortable with a bore of more than .030" over in a performance application without sonic testing first. 350 pistons ARE readily available in .080 over. Good luck, and...
RACE ON!!!
Old Dec 22, 2003 | 10:58 PM
kcl98's Avatar
kcl98
I've got a .040 over L98 in my Camaro that's running just fine - 68,000 miles on the re-build & running high 12s. .060 might be iffy, but I think .040 is fine.
KC
Old Dec 23, 2003 | 01:47 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: L98 block over bore max? (kcl98)
A .040" overbore is probably "safe", 98% of the time. Even .060" is safe 90% of the time. I would just hate to be the guy to spend the time and money, and find out the hard way, that my block was the exception to the rule. Good luck, and...
RACE ON!!!
Old Dec 24, 2003 | 05:54 PM
JAKE's Avatar
JAKE
When considering going more than .030 over, have the block sonic checked. You'll want the thickness to be there on the thrust walls.
I've had BBs crack at the bottom of one bore on only a .060 over-bore. Blocks are different, some can take it , some can't.
Jake
To L98 block over bore max?
