Intake gasket part # needed - '89 L98
Old Dec 24, 2003 | 09:26 AM
shotchkiss's Avatar
shotchkiss
Default Intake gasket part # needed - '89 L98
Does anyone have the Felpro part # for an intake manifold gasket for this car? The gaskets should have the rear cooling passages restricted with just a small hole in them, a least that's the way the factory ones were. The only gaskets I've found so far are ones that have this passage open like the 1205, which I don't think are the right ones. Help please.
Old Dec 24, 2003 | 09:32 AM
Corvette0096's Avatar
Corvette0096
Default Re: Intake gasket part # needed - '89 L98 (shotchkiss)
#1204
Old Dec 24, 2003 | 01:11 PM
JOHN89's Avatar
JOHN89
Steve,
You have email. I assume the package arrived OK. I have used both the 1204 & 1205. Both work. I personally wouldn't use the restrictor plates but your call. I put a receipt in the package that has the Lingenfelter part numbers for the last gaskets that I used with the intake.
Good luck with the install!
John
Old Dec 25, 2003 | 12:23 AM
JAKE's Avatar
JAKE
Default Re: Intake gasket part # needed - '89 L98 (Corvette0096)
I don't use the gaskets that restrict the coolant flow at the rear either.
Jake
Old Dec 25, 2003 | 12:25 AM
scorp508's Avatar
scorp508
Don't worry about the restrictor thingies. :nonod:
Old Dec 26, 2003 | 09:36 PM
shotchkiss's Avatar
shotchkiss
Default Re: (scorp508)
I'll just run the 1205's I have then. Thanks guys
To Intake gasket part # needed - '89 L98
