Question on changing tires
Old Dec 27, 2003 | 10:33 AM
19vette91's Avatar
19vette91
Default Question on changing tires
I'm looking to buy a cordless drill or Impact drill to change tires at the race track. I can't find anyone at the hardware stores that can agree on what size I need. I hear 14v to a 18v cordless drill Is ok. Then I hear that only a cordless impact drill will work. Has anyone on this forum changed their tires with a cordless device that can offer me some help? Also which drive Is needed 1/2 or 3/4 ?
Thanks!!!
Old Dec 27, 2003 | 10:51 AM
SPEED750's Avatar
SPEED750
Default Re: Question on changing tires (19vette91)
I would recommend a 1/2" impact drill.Without the impact, a drill won't be able to bust loose your nutz.Go check out the selection at sears.I saw some nice Dewalts there.I wold also get the highest voltage you can afford. 18volt
or bigger should do fine. :chevy
Old Dec 27, 2003 | 04:20 PM
bart15's Avatar
bart15
Default Re: Question on changing tires (SPEED750)
:iagree:
Old Dec 27, 2003 | 07:29 PM
USA-VET's Avatar
USA-VET
No drill will work!! :nono: :nono: :nono: :nono:
Old Dec 28, 2003 | 12:26 AM
JCAIRE2's Avatar
JCAIRE2
You'll still need to torque them with a torque wrench. NEVER trust an electric impact to tighten a bolt or nut completely.
Old Dec 28, 2003 | 12:33 AM
scorp508's Avatar
scorp508
Default Re: Question on changing tires (JCAIRE2)
Is there any cordless unit that can break 100 ft/lb free? :confused:
Old Dec 28, 2003 | 05:05 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Might want to look into this item... :thumbs:
http://forums.corvetteforum.com/zerothread?id=690036
Old Dec 28, 2003 | 12:33 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Question on changing tires (scorp508)
Not that I'm aware of. We use the 1/2" drive snap on cordless impacts at work and if it's torqued over ~50ft. lbs., you have to break it with a ratchet or bar first.
Old Dec 28, 2003 | 06:08 PM
19vette91's Avatar
19vette91
Thanks for the help guys, you saved me $250.00 I was about to spend $300
on a cordless Impact wrench and the Roadpro Impact Is only $40 plus $10 shipping.
:party:
[Modified by 19vette91, 11:24 PM 12/28/2003]
To Question on changing tires
