I am going to install Superram (base, runners, plenum) to my stock 350 engine with 74219 camsgaft and propably AFR 190-195 cylinder heads (or something cheaper).
(btw I have -88 automatic vette)
I would like to also upgrade my transmission to get the "launching" better.
I am currently running with 3.07 gear ratio and I was wondering would a higher rear end do me any good?? I was browsing TPIS website and saw that they are selling 3.73 gear sets.
I'm also wondering about the torque converter and shift kit. Ive read from past posts that 2200-2400 might be best for my setup?
Was it Transgo who made the best shift kits?
My vette is daily driver during summer. I like to keep it very driveable but it has to have torque and some serious HP!
I have a combination that is very similar to what you are going to build. I installed 3.45 gears to help with the holeshot and I installed a 2800 to 3200 RPM stall speed with lockup to help with the 60 ft times. Before I installed the 2800 to 3200 stall speed I had a 2400 RPM stall speed. On street tires I could smoke the tires any time I wanted but with the slicks the engine dogged until 2600 or 2700 RPM and then took off, that is why I went with the higher stall speed. If you are not planning to race the car with slicks, stick with the 2200 to 2400 stall speed.
with a little 350 motor then the 340-350 gears will work out fine in a 383 a 320-330 gears will work nicely and a 406 a 307 is just right now anything larger than a 406 then the 307 will be too much and i would sugest to go larger tires is everybody confused yet :cheers:
but i did run a 307 gear 350 with a converter myself that was only because the 350 motor i knew at the time would be pulled in favor of more cubes later on :D :cheers:
I have the 2.70 gears, does this mean I'm only limited insde the 2.?? ratios or can I go into the 3.** ratios as well?
The 2-series carrier and 3-series carrier for the D36 are supposed to be a bit different, but I dont know enough about it to tell you for sure. I know there are places who build gears lower than 3.07 for the D36 though. (3.33, 3.54, 3.73.....)
TheStef wrote:
"I have the 2.70 gears, does this mean I'm only limited insde the 2.?? ratios or can I go into the 3.** ratios as well?"
No, you're not. It's my understanding that there are aftermarket 3.xx gears that were designed to work with the Dana 36 2 series rear ends however, the closer you get to 4.xx, the easier it is to break them. There are more than a few people on the Forum who have done this (upgraded without problems AND upgraded and broken them!). Best bet is to hit the archives. The info is definitely there...
