Headers for LT4
Old Dec 28, 2003 | 01:14 AM
Kevs LT4's Avatar
Kevs LT4
7th Gear
Default Headers for LT4
I was thinking of bolting on a set of headers for my LT4 coupe. However, I don't know how much of an increase in horsepower it would make without additional modifications. I'm not interested in cam replacement. The car is stock with the exception of Borla mufflers and a K&N air filter. I wondered if anyone else had installed headers to a stock LT4 and if they felt much of a difference.
Old Dec 28, 2003 | 08:23 AM
RichS's Avatar
RichS
Default Re: Headers for LT4 (Kevs LT4)
Before I started to mess with the motor I had all bolt ons like : Longtube headers, Corsa cat back, MSD box,wires, coil, 52mm TB, 4:10 gears, Vortex. The car went 12.5-12.6 and the motor was not touched. So yes they will help. :cheers:
Old Dec 28, 2003 | 05:05 PM
MaddMaxx's Avatar
MaddMaxx
I just added a pair of TPIS LTs to my LT4 this month and am very happy with the improved performance. The car sounds a lot better and pulls much harder out of the hole.
Old Dec 29, 2003 | 07:48 PM
kcl98's Avatar
kcl98
If you're going to do it - get long tubes - I put the Lingenfelter/Hooker shortys on my old LT4 back in '97 along with a Borla 2&3/4" Challenge system & didn't see a single tenth or mph at the drag strip. I didn't dyno it, so I can't be totally precise, but it certainly wasn't worth the money. I've heard the Borla & even Corsa stuff doesn't flow as well as B&B Tri-Flow - Tri-Flow with X-pipe is the hot setup - at least on my friends' 3 ZR1s - X-pipe is loud though.
Old Dec 29, 2003 | 10:12 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
longtubes will make a difference...then...gears :thumbs: :cheers:
Old Dec 29, 2003 | 10:50 PM
NASCAR314's Avatar
NASCAR314
Default Re: Headers for LT4 (Vette Ed)
:confused:
How do you guys put on Long Tube headers on a 96 Model with the OBD-II system and 4 oxygen sensors???
And still pass emmissions ???
:confused:
Old Dec 30, 2003 | 07:38 AM
RichS's Avatar
RichS
Default Re: Headers for LT4 (NASCAR314)
:confused:
:confused:
You can use O2 simulators on the 2 rear sensors or have them tuned out. They do not afect the running of the car, they only moniter the converters to make sure they are working properly. They have nothing to do with tuning of the motor.
Old Dec 30, 2003 | 11:25 AM
SouthernSon's Avatar
SouthernSon
If I were you, I would look at the Exotic Muscle headers. I put the TPIS headers on a couple of months ago and was really disappointed with the workmanship. I had to grind out the weld bead on the inside of the tubes, had to open up the bolt sleeves to align bolts with heads and had to bend stove pipe to allow clearance of valve cover. I still cross threaded one bolt into head because the bolt sleeve on the header was WAY off of perpendicular with head surface. I did manage to retap the hole and get it tight. All in all it took the better part of a day to clean up the headers with the air grinder. NO excuse for such bad rigging in the jigs before they welded them up. No more TPIS for me. However, having ranted enough about that, I did see 340.8 RWHP and 334.5 torque on the dyno with the mods in my signature. An increase of 50HP or so from stock.
Old Dec 30, 2003 | 11:32 AM
NavyVet's Avatar
NavyVet
Default Re: Headers for LT4 (southern_son)
Plus, Merle at EM has a slick set of pre-fabbed adapters to connect his LT headers to a Corsa cat-back system. You have 2 options here - Random bullet cats or a blank pipe that fits in their place. He developed the jig to make these using my LT4 with his EM headers and the Corsa PowerPulse catback I already had, so everything fits just right.
Old Dec 30, 2003 | 12:52 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
You will definately notice a performance increase, but if you don't use cats, the noise will be much louder with an aftermarket exh system. I would love to put on the long tubes and random cats on my car someday...
Old Dec 30, 2003 | 01:50 PM
CNTDRV55's Avatar
CNTDRV55
Default Re: Headers for LT4 (RichS)
You can use O2 simulators on the 2 rear sensors or have them tuned out. .
RichS,
Whats an O2 sim, and what do you mean by 'tuned out'?
Old Dec 30, 2003 | 01:57 PM
tjwong's Avatar
tjwong
Default Re: Headers for LT4 (tailgunner)
What Rich means by "tuning it out" is that you can have your PCM recalibrated to remove the DTC switch so that it won't throw a DTC for the missing sensors. Or you can purchase two sensor simulators and plug them into the harness where the sensors were. These little guys sends a dummy signal to the PCM so that the PCM will thing all is well from the sensors that are no longer there. Here is where you can purchase the sims:
http://www.casperselectronics.com/cg...gi?product=HID
Old Dec 31, 2003 | 02:42 PM
CNTDRV55's Avatar
CNTDRV55
Default Re: Headers for LT4 (tjwong)
Very cool. Thx :cheers:
Old Dec 31, 2003 | 02:58 PM
No Go's Avatar
No Go
Something else to know is all the currently available long tube headers require further exhaust fabrication to connect to the rest of the exhaust system.
I believe DRM used to sell Watson headers that plumbed right into the factory exhaust. No longer available though...:(
To Headers for LT4
