C-4 Injector Drive loss/faulty KEYPASS module?
Providing a ground for the start enable circuit is one, the one that shows up first. There is a second signal.
The VATS will reduce a reference voltage thereby telling the ECM the VATS sees the correct resistor. When the ECM sees a volatage drop signal from the VATS, the ECM will pulse the injectors. I believe its looking for around 2.5 volts, down from the 5 volt signal. Am at work and can't give ya the Helm's page number. Gordon K told me there is also a proprietary HZ signal not mentioned in any manual. The two step VATS prevents a "hot wire" start. A thief could jump the wires, get the engine to crank, BUT the ECM will not pulse the injectors. Thus the VATS provides two layers of protection, engine crank and injector pulse.
I doubt signal loss will cause problems after the engine has started and the key moves to the run position. Not sure on this. Suspect the problem is elsewhere.
Interesting problem.
dlmeyers 90 coupe zf6 3 speed shocks
If you have the service manual, head for Chart A-3, driveability and emission. A favorite of mine.
Assuming this is an 89 L98, look for "Engine Cranks but will Not Run". The basic idea here is to make sure we know if there is spark or no spark, injector pulse/no pulse, injector voltage but no ground, etc.
So, are you using a "noid" light to determine injector status?. Are you seeing continuous voltage or no voltage on the injector harness. IF the light is illuminated continuously, it does not pulse, the injector driver is not providing a ground. Since you have replaced the ECM, I would suspect the ECM is not seeing an RPM reference signal and then not providing a ground, thus no pulsing injectors.
A little system review may be in order. Anytime the injector harness is powered, harness wires have voltage, the system is just waiting for a ground provided by the ECM's injector driver. The ECM is looking for an RPM signal from the HEI. Your HEI distributor module pin R connecting to Cavity B on the 4 wire connector waaaaay back there on the distributor carries an RPM signal to the ECM(Check your schematics for the 89). I have heard of that connector going bad, the module going bad, etc. IF I were to make a bet, I suspect the ECM is not getting this reference signal and the injector drivers are not providing a ground. Not being able to test this, only going on what is posted. Further, I am very suspicious when "heat" or run time is involved. I lean towards HEI components/RPM reference signal
I am SPECULATING.
Again, head for the service manual trouble shooting steps, do a physical inspection of the distributor wire harness, etc. There is test inolving that connector and cavity B. Keep us informed. Eternally curious.
By the way, I too am starting my New Year out right. Last night, the darn air bag light set a code 16 so I will be wrenching New Years Day. I feel your pain.
Good luck with your repair.
Next look under the steering columb area and locate your ign. harness.
You should see what looks to be an orange insolated wire running along with
the ign. harness wires.Cut that in half and inside that are 2 small white wires.
now you have your ign cylinder side and your ecm side.Simply place the resistor across the 2 white wires on the ecm side. and leave the ign side unused. :)
Again, good luck.
dlmeyers 90 coupe zf6 3speed shocks
