84 Crossfire keeps cutting off.
Old Dec 29, 2003 | 12:07 PM
84BlackVette's Avatar
84BlackVette
8th Gear
Default 84 Crossfire keeps cutting off.
Hi, hope someone can help. Car runs and idles fine when its cranked up for the first time of the day. However, after driving it awhile and after shutting down and restarting, it cuts off at idle and at very low speeds. happens like clockwork. any ideas? thanks!! :confused:
Old Dec 29, 2003 | 12:22 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: 84 Crossfire keeps cutting off. (84BlackVette)
Have you tried the CrossFire Forum? http://www.crossfire.webhop.net
good luk
tony
PS: check/change fuel filter. :auto:
Old Dec 29, 2003 | 12:29 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Maybe thats why it's called the Ceasefire. :yesnod:
Old Dec 29, 2003 | 01:25 PM
Dominic Sorresso's Avatar
Dominic Sorresso
How many miles on the car? Have you checked fuel filter? Any codes set? IAC motors or vacuum leak on plenum lid.
Old Dec 29, 2003 | 02:33 PM
byte_me's Avatar
byte_me
Ceasefire??? Ouch, that Hurts.... :U
I had a similar issue with my CROSSfire and it turned out to be rectified with a tune up (plugs, cap, rotor and coil and O2 sensor) as well as a fuel filter...It was running a bit rough and after exiting the highway and turning it off...it would not want to start....May also want to look at the fuel Pump and filter sock on it....
Do yourself a favor- if you go into the tank to take a peek...put an 85 Vette Fuel pump and new fuel strainer in it...it will be like a whole new car!
The crossfire site mentioned above is a great place to get info on the Crossfire... :thumbs:
Old Dec 29, 2003 | 03:23 PM
84BlackVette
8th Gear
Default Re: 84 Crossfire keeps cutting off. (byte_me)
Thanks for the help guys. I've got the next few days off and hope to use the time to try all of your recommendations and put the problem to rest. Happy New Year!! :smash:
To 84 Crossfire keeps cutting off.
