Spring Compressor Tool
Old Dec 29, 2003 | 03:53 PM
Jeff S's Avatar
Jeff S
Default Spring Compressor Tool
Anyone know where I could get a compressor tool for the fiberglass leaf springs, as shown in the GM shop manual? Does GM sell these? I've used a floor jack to unload the springs so far, and it works, but seems like it'd be better with the tool - more room to work, positive control of the spring, and the ability to unload both sides at once.
Old Dec 29, 2003 | 07:28 PM
Z-PDX's Avatar
Z-PDX
Default Re: Spring Compressor Tool (Jeff S)
Jeff -
You are about 2 miles from my house. Email me and we can get together to get you some help. I have done both ends of my car without special tools. No problem.
-Z
Old Dec 29, 2003 | 08:23 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Default Re: Spring Compressor Tool (Z-PDX)
Z-PDX, if you have some specific tips to share, I would like to hear them. I am going to be doing a lot of rear end work on my 87 here shortly.
Old Dec 29, 2003 | 08:58 PM
bogus's Avatar
bogus
this is easy... raise your car, using a jack and jack stands... then, using the jack, unload the spring, loosen the bolts and lower the jack.
easy. :thumbs:
Old Dec 30, 2003 | 12:02 PM
Jeff S's Avatar
Jeff S
Default Re: Spring Compressor Tool (bogus)
Thanks for the info guys, and thanks for the offer Z-PDX. I'm doing OK so far, but if I could use some help, I'll let you know.
The problem I ran into when lowering the spring after the bolt was detached was that the angle of the spring (due to the bend) got so large that it wanted to push the jack toward the center of the car. I just left it there with some load still on the spring, but would have preferred to have the spring completely unloaded, or controlled by the compressor tool.
Old Dec 30, 2003 | 12:58 PM
Z-PDX's Avatar
Z-PDX
The only things I can add to Jeff's tips are too get the car as high as you possibly can. (I use truck jacks)
And place a block of wood on the jack so you don't have metal in contact with the spring.
It also help to align the jack with the direction of spring travel. This way as you unload the spring, the jack travels in the same direction and you won't lose the load.
-Z
Old Dec 30, 2003 | 01:18 PM
kohlbear's Avatar
kohlbear
Do you know if a 87 z52 has front springs?
Old Dec 30, 2003 | 01:48 PM
QuikZilver's Avatar
QuikZilver
Default Re: Spring Compressor Tool (kohlbear)
Coil springs? No, unless you have put coil overs on. The C4 has a transverse front spring similar to the rear spring.
To Spring Compressor Tool
