Pulling Codes from a 96
Old Dec 31, 2003 | 05:01 PM
VetteLT4's Avatar
VetteLT4
Default Pulling Codes from a 96
How do you go about pulling codes from a 96? I checked http://www.c4vettes.com/ecm.htm but they only list through 93 and say I need a special tool or the service manual for a 96. I hope theres a way without the tool because I dont have it. Any help is appreciated. car only has 41,000 on the clock and im really upset its throwing codes.
Old Dec 31, 2003 | 05:07 PM
96GS#007's Avatar
96GS#007
Default Re: Pulling Codes from a 96 (VetteLT4)
Take it to AutoZone and they'll pull the code(s) for free.
On our '96s, you need either a scan tool or diagnostic software & a laptop to pull PCM codes.
Old Dec 31, 2003 | 11:40 PM
DVNCI's Avatar
DVNCI
Just make a jumper wire and connect pins 4 and 12 on the diagnostic port below driver's footwell. Then turn ignition to ON, do not start car!
It will start blinking codes at you.
Old Dec 31, 2003 | 11:42 PM
DVNCI's Avatar
DVNCI
Default Re: Pulling Codes from a 96 (RUKWKR)
Well, I'm kind of curious now as to what others say. My car is a 96 but has a 95 PCM so maybe the procedure I mentioned does not work on a 96??????
Old Jan 1, 2004 | 12:00 AM
96GS#007's Avatar
96GS#007
This will NOT work on a '96 with OBD II. You can pull CCM codes this way, but not powertrain codes from the powertrain control module (PCM).
Old Jan 6, 2004 | 04:34 PM
VetteLT4's Avatar
VetteLT4
Default Re: Pulling Codes from a 96 (96GS#007)
ok so before i bite the bullet and take it in, its certain i cant pull SES codes on my own without a special tool?
Old Jan 6, 2004 | 04:41 PM
CNTDRV55's Avatar
CNTDRV55
Will it work on OBD I? I ask because I have seen some procedures for getting all codes from ALL modules (e.g. PCM, rtd, ccm,etc).
Are you saying that this procedure is for pre-OBDII? Or that it is entirely bogus?
[Modified by tailgunner, 3:42 PM 1/6/2004]
Old Jan 6, 2004 | 05:25 PM
TravisD's Avatar
TravisD
Correct - you need to have a scan tool of some sort.
Most auto parts stores are now selling relatively (~$100) tools that will read and reset OBDII codes. It's a decent tool for the tool box if you expect to do any of your own work on a 96 or up vehicle. The good thing is that it's standard so this will work on pretty much any 96 and up vehicle.
They way I see it, it's not really different from any other tool you buy. A little more expensive maybe, but it's still not a wasted expense. Figure that a trip to the dealer to read/reset a code might cost you $40 or more (and time!) and it'll quickly pay for itself. At least that's how I see it...
It's really nice for when you do some work under the hood and either forget to reconnect something, or otherwise cause a code with no real failure. Sucks having to go to someone else and pay them to fix your "oops" :D
Old Jan 6, 2004 | 05:29 PM
96GS#007's Avatar
96GS#007
Default Re: Pulling Codes from a 96 (tailgunner)
It should work on all OBD I cars, although the specific pins are different for '93 and earlier vs '94 & '95 (different # of connector pins on earlier cars vs '94 and up)
Old Jan 6, 2004 | 06:32 PM
VetteLT4's Avatar
VetteLT4
ok, in she goes at least for a preliminary check on thursday. with the amount of miles she has, i sure hope its cheap. i just dropped $360 to have my daily fixed today, i cant handle vette bills
To Pulling Codes from a 96
