rim offset question
Old Jan 1, 2004 | 07:19 PM
CYLT4's Avatar
CYLT4
Default rim offset question
i would love to put a set of 11" rear rims on my 96 but i do not want them to stick out past the fender lip and i do not care for the fender flare like the grand sports sooooo my question is will the 38mm offset for the 84-88 cars work on the rear of a 96 and if they will fit, will the 18mm difference in the offset cause the rim to sit in the fenderwell or will it cause it to stick out even more? if they will sit back in the fenderwell is there a clearance problem on the backside?
Old Jan 1, 2004 | 07:40 PM
DroptopMan's Avatar
DroptopMan
Default Re: rim offset question (CYLT4)
I put the GS offset, Replica ZR1's on my 94 and they fit great. They don't stick outside of the fender well, or ever touch in hard cornering. I bought the entire set on the Internet from AAARims with tires mounted. The TA KD's are great around corners as well. Front tires are 275/40 17's, and backs are 315 /35 17's.
Old Jan 1, 2004 | 08:01 PM
Bans25's Avatar
Bans25
84-87 should use the +36mm offset, 88-96 should use the 50mm offset.
The tires will stick out ever so slightly even with the 50mm offset, but not bad at all (everyone uses these).
If you put the +36mm offset on a 88-96 (non-zr1 vette) they will stick out quite a bit..
Old Jan 1, 2004 | 08:32 PM
CYLT4's Avatar
CYLT4
Default Re: rim offset question (Bans25)
thanks for the response. i have a little christmas cash to spend. trying to figure out all my rim options :cool:
Old Jan 1, 2004 | 09:34 PM
BAM92's Avatar
BAM92
I saw a yellow 96 with GS wheels. That black and yellow really stand out. :thumbs:
To rim offset question
