hooker front y-pipe?
Old Jan 2, 2004 | 08:25 AM
devilfish's Avatar
devilfish
Default hooker front y-pipe?
anyont got trouble install it?
Old Jan 2, 2004 | 09:26 AM
TA's Avatar
TA
Default Re: hooker front y-pipe? (devilfish)
I don't have headers so I'm only going by what I've read on here. I believe that Hooker redesigned the y-pipe at some point due to the older ones not fitting properly. From what I've read the newer designed y-pipes fit pretty good.
Old Jan 2, 2004 | 09:42 AM
Corvette0096's Avatar
Corvette0096
I have one on mine and it fits like a glove. :yesnod:
Old Jan 2, 2004 | 09:54 AM
LD85's Avatar
LD85
Default Re: hooker front y-pipe? (Corvette0096)
Mine has a mis-alignment of @ 12mm, I am in the process of cutting the pipe to relax it so I can bolt it on with the proper alignment, then I will reweld the gap so that the headers are not "squeezed" towards each other as they are now.
Old Jan 2, 2004 | 11:18 AM
shotchkiss's Avatar
shotchkiss
Default Re: hooker front y-pipe? (ld85)
Mine didn't fit well and had to be cut and re-bent
Old Jan 2, 2004 | 12:31 PM
1MoorTym's Avatar
1MoorTym
I just bought and installed it this past fall. It fit just fine on my 89 6spd.
To hooker front y-pipe?
