Valve Cover Gaskets
Old Jan 4, 2004 | 07:25 PM
corvettephreak's Avatar
corvettephreak
Default Valve Cover Gaskets
I was just wanting to get some input on Valve Cover Gasket recommendations. What is a good replacement and what do you all think about the cork gaskets. I had a set of gaskets (cork that is) installed approx 2 mths ago and they seem to be leaking already. I can really notice it when I first startup the car and as it gets warm I can smell the burning oil and notice that it has oil below the valve cover and looks to be dripping on the exhaust. The mechanic I used is no longer in business and may have done a sorry job. So your recommendations is much appreciated. Thanks
Old Jan 4, 2004 | 07:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Valve Cover Gaskets (corvettephreak)
Get a set of the blue FelPro Perma Seal gaskets (at AutoZone) and don't look back.
Old Jan 4, 2004 | 07:57 PM
91z07's Avatar
91z07
:iagree: :thumbs: BTW, check the torque on your bolts, overtightening or unequal torque can cause leaks.
[Modified by 91z07, 7:01 PM 1/4/2004]
[Modified by 91z07, 7:04 PM 1/4/2004]
Old Jan 4, 2004 | 08:30 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I just pulled my covers off a few days ago. They were a soft rubber gasket and I never ever saw a leak. They look so good I'm going to reuse them. Not sure who makes them though.
:cheers:
Old Jan 4, 2004 | 11:01 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
The more expensive Fel-Pro's are probably a better gasket, but when I put new gaskets on my 85 several years ago, I used the cork type. Used my inch pound torque wrench to tighten the valve cover bolts. When changing the oil I use my inch pounds torque wrench to check the tightness of the bolts if I notice any seepage. No significate leakage yet.
Old Jan 4, 2004 | 11:07 PM
Tourney3p0's Avatar
Tourney3p0
Overall I've had a lot better luck with rubber than cork.
I picked up some blue rubber Felpro gaskets for when I was painting my valve covers. When I removed the valve cover, I had an orange rubber gasket that was still in excellent shape. I ended up reusing them and have since put a thousand miles on the car with no leaks.
Old Jan 4, 2004 | 11:57 PM
AGENT 86's Avatar
AGENT 86
Default Re: Valve Cover Gaskets (Tourney3p0)
Those are probably the same orange ones I plan on reusing :D
Old Jan 5, 2004 | 12:33 AM
JAKE's Avatar
JAKE
Default Re: Valve Cover Gaskets (AGENT 86)
The rubber ones with the thin metal band sandwiched between two layers of rubber work best for me.
I've tried the high dollar cork variety that also has a metal band but since I'm so ham-fisted I tend to make the metal band squeeze out. I now use hold downs too, to better equalize the clamping force.
Jake
Old Jan 5, 2004 | 04:28 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Valve Cover Gaskets (65Z01)
:iagree: Only way to go
To Valve Cover Gaskets
