right headlight
Old Jan 5, 2004 | 04:53 PM
ojaijim's Avatar
ojaijim
Default right headlight
When I bought my 89 I had and have had problems with the headlight spinning around and stopping with the light facing down. Do I need a new motor? :confused: :confused:
Old Jan 5, 2004 | 06:22 PM
ffvetteman's Avatar
ffvetteman
Default Re: right headlight (ojaijim)
Sounds like the gear inside the motor is bad but I'm no expert on those (yet)
I think you can take it apart and replace the nylon stock gear with a bronze one. That may be causing the problem.
Old Jan 5, 2004 | 06:39 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: right headlight (ffvetteman)
:cheers: It may well be the gear, but often it is three Delrin bushings that support the gears
The bushings are cheap, MAD or Ecklers, I would start there.
There used to be and probably still are a number of very good posts in the Tech Tips section of the Forum
:seeya
:steering:
Old Jan 5, 2004 | 07:24 PM
Strick's Avatar
Strick
Does the motor keep cycling?
Old Jan 5, 2004 | 10:53 PM
ojaijim's Avatar
ojaijim
Default Re: right headlight (Strick)
Yes the motor does continue to recycle. :flag
To right headlight
