need tips on spark tuning...
I'm not an expert, but it seems to me that would indicate to much timing in this location of the spark table.... also at crusing speeds i think i feel a itty-bitty surge... could that be because of the EGR? I still have the EGR active even though I have a cam with a much larger overlap than stock.. so I try turning the EGR off to try and eliminate this? Also, I'll post my spark table as soon as I convert it to a postable file..
thanks!
*edit*
Here are the spark tables I'm running... see sig for cam specs! (CLICK TO ENLARGE)
Spark. Vs RPM Vs Load (0-4000RPM)
Spark Vs RPM Vs Load (4000-7500RPM)
Coolant Temp vs. Spark
what am I doing wrong?
[Modified by BluByU, 8:10 AM 1/9/2004]
Did you put in a different torque converter? That cam is real close to the LT4 HOT Cam. I think most automatic guys run a 2800rpm stall to eliminate the surging.
When I begin pulling out timing to I start at the place i noticed the rolling idle surge? (700-900 rpm, 45-60MAP) and work from there? 2* at a time like you said? Also, do you see anything espeically out of the ordinary about my timing tables?
*edit *
another TCC question..
why would you want the TCC to unlock at a lower TPS% than the factory settings at a given speed?
[Modified by BluByU, 1:00 PM 1/9/2004]
I have a stock converter on a 218/224 114 cam.
Idle areas take a delicate balance of fuel, spark, commanded idle, throttle stop adjustment, and sufficient IAC headroom.
My car wanted more timing.
Drive to Sarasota and I'll try to help.
If you are using DataMaster send me a datalog file and advise of where the surging is taking place and I will take a look and see for you :)
[Modified by tjwong, 4:18 PM 1/9/2004]
Nothing jumps out at me as being out of the ordinary with your timing maps. Just needs a little fine tuning :)
When tuning a spark map for a modifyed engine where is what is a good way to start (or best method to proceed). Do you just assume you can run more spark if you assume you will always run 93 octane and just bump the whole timing table up a certian % accross the whole board? Also, I noticed in my old PCMforless tuning that they drastically increased the low RPM spark advance.. is there some performance payoff in doing this? or does this jsut mask the idle for engines running bigger cams?
[Modified by BluByU, 6:18 AM 1/12/2004]
I would not increase the whole map across the board. If you're running a modified version of an LT1 or LT4 timing map from GM, you should be pretty close other than high load/low rpm areas (which have always seemed a little conservative IMO) and where you have cam surge.
Light load areas of the timing maps really boil down to driveability characteristics. If the car drives fine, leave well enough alone. If it surges, fix those areas of the map. Once you're satisfied with the driveability, then it's time to tune WOT. To do that you need a dyno and wide-band O2 sensor. WOT tuning includes fueling changes to optimize the A/F ratio and timing changes. FWIW, I made more power with less timing than stock above 6000rpm.
Unfortunately it is a repetitive process.
I dropped quite a bit of timing (see below) with little effect to performance and or surging.. before that I had tried eliminating the EGR but that didnt help either...
here is the table which illustrates the difference between the GS table which i'm running now and my old table from PCMFORLESS..
values shown are how much less timing i'm running now in the indivated spark cell..
wtf :mad :confused:
I'm not sure of the specifics since I have a 6 speed, but....I've heard of people having similar issues like what you're describing due to the lock-up feature of the torque converter locking and unlocking.
Generally cam surge is in the off-idle to ~1600rpm range.
*edit*
After looking at my datamaster logs I noticed there is something not right about the fuel trims.. I used to have the cruise trims dead on.. but now it seems the driver side of the engine is running quite lean.. almost a 10 count difference from the right fuel trims... conicnidently, This is the same side of the engine I have a ticking lifter.. I wonder if the lifter collapsed fully and isn't opening the valve enough.. also I suppose this could be cause by a accum leak and or a fuel injector problem.. looks like i'm whipping out the stehescope to check all the injectors are firing again.. intake is comming off tomorrow am so i can replace the lifter.. this should take care of any protential intake manifold leaks.. aggghh..
[Modified by BluByU, 7:28 AM 1/16/2004]
