'84 Hydraulic Clutch Line Replacement
Old Jan 9, 2004 | 06:55 PM
415ZR1's Avatar
415ZR1
Default '84 Hydraulic Clutch Line Replacement
Need to replace the clutchline. This item is no longer available from GM. Is any one doing a repro part or a braided line replacement? Anyone have the fitting dimensions at the master cylinder and slave cylinder? Would like to have a replacement ready to go before taking the car out of service.
Thanks, John
Old Jan 9, 2004 | 06:57 PM
bogus's Avatar
bogus
Default Re: '84 Hydraulic Clutch Line Replacement (415ZR1)
I am sure that the part is no longer available from GM...
and I don't think anyone else makes one.... so.... I am sure someone can make you one. It ain't nothing much more than a long brake line!
I would remove the existing hose, and find a shop that makes hydraulic lines and see what they can do!
Old Jan 10, 2004 | 12:47 PM
Dominic Sorresso's Avatar
Dominic Sorresso
415,
I just took the clutch hose line off my 84. Its in pretty good shape. I am replacing the 4+3 with a ZF6 which is why I have hose available.
Let me know if you're interested in buying it. $45 + shipping
Old Jan 10, 2004 | 01:00 PM
bogus's Avatar
bogus
Default Re: '84 Hydraulic Clutch Line Replacement (Dominic Sorresso)
:thumbs:
To '84 Hydraulic Clutch Line Replacement
