AutoTap question
Old Jan 10, 2004 | 01:00 PM
CNTDRV55's Avatar
CNTDRV55
Default AutoTap vs carputing's lt1/4 edit questions
Is Autotap's OBDII tool just for scanning and TS? I don't see on their page where you can 'tune'... True?
Also, can you pull codes (scan) with carputing's lt1/4 obdii tool or just tune?
I want a tool that scans codes AND tunes.... :yesnod:
[Modified by tailgunner, 12:14 PM 1/10/2004]
Old Jan 10, 2004 | 01:21 PM
tjwong's Avatar
tjwong
Default Re: AutoTap vs carputing's lt1/4 edit questions (tailgunner)
There isn't a tool out there that can SCAN and TUNE. Auto Tap, EASE, EFiLive are all just scan tools none of which can do any tuning. Some like the GM TECH2 can do some actuator manipulation and perform a series of tests. But none can actually alter the PCM programming. A TECH2 does have the ability to flash program a PCM but it can't alter that program from GM, it can only load it to the PCM.
Old Jan 10, 2004 | 02:14 PM
CNTDRV55's Avatar
CNTDRV55
Default Re: AutoTap vs carputing's lt1/4 edit questions (tjwong)
Seems odd. You might think that if a program could pull down PCM data, alter it, and then upload the changes, it could certainly pull some DTCs. :confused:
Bummer man. Thanks. :cheers:
To AutoTap question
