90 cruise control problems, need help
Old Jan 10, 2004 | 04:06 PM
mphy98's Avatar
mphy98
Default 90 cruise control problems, need help
my cruise does'nt work, any common problems? i have a 90, the multi function switch needs to be pulled a coulpe of times before the brights come on, would this be a good place to start?
Old Jan 12, 2004 | 12:06 PM
frankrizzo1's Avatar
frankrizzo1
Default Re: 90 cruise control problems, need help (mphy98)
check your vacuum lines....
the cruise control on my 94 wasnt working.....
i found a cracked and disconnected vacuum line at a t connector close to the battery area....
good luck...
