Valve Cover Question
Old Jan 11, 2004 | 05:07 PM
david85's Avatar
david85
Default Valve Cover Question
If I wanted to go to an aftermarket valve cover, would I need the short, or tall for my 85? I know the covers on the car have the bolt on the outside edge but wasn't sure which of the two I needed...
thanks,
david
Old Jan 11, 2004 | 05:19 PM
JAKE's Avatar
JAKE
Default Re: Valve Cover Question (david85)
You'll probably have power brake booster clearance problems with the tall ones. I had to have a set of tall ones notched on the driver's side rear cover on an 86 I built recently. Had to go with tall ones to clear the Jesel shaft rocker setup.
I installed new ones on my 86 a few months ago. Went with AC Delco chromed covers which have "Chevrolet" stamped in them.
They're thicker than some of other the offerings and shouldn't warp like the stock ones did.
Hope this helps.
Jake
Old Jan 12, 2004 | 06:58 AM
LD85's Avatar
LD85
Default Re: Valve Cover Question (JAKE)
Go with Proforms, they are this much taller and still clear
Old Jan 12, 2004 | 08:07 AM
david85's Avatar
david85
Thanks you'all. I've had my eyes on a aluminim set with flames engraved... But wondered about clearence problems.
Old Jan 12, 2004 | 09:28 AM
LD85's Avatar
LD85
On my 85,,, the wiper motor cover is/was the clearance problem.
Old Jan 12, 2004 | 10:02 AM
Corvette0096's Avatar
Corvette0096
Default Re: Valve Cover Question (ld85)
Yes the wiper motor is the problem. I went with a set of talls that where custom made.
[Modified by Corvette0096, 7:02 AM 1/12/2004]
Old Jan 12, 2004 | 10:51 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Valve Cover Question (Corvette0096)
:thumbs: :thumbs: nice
Old Jan 12, 2004 | 11:00 AM
LD85's Avatar
LD85
:iagree: Very nice valve covers!
Old Jan 12, 2004 | 11:31 AM
Corvette0096
They are made by the same company that does LPE and Callaway.
Old Jan 12, 2004 | 08:01 PM
8835thL98's Avatar
8835thL98
thanks,
david
To save money go to your local O'Reilly and buy some silver finish 1500 degree paint and take your valve covers off and paint them just like i did, saves alot of money and looks brand new....
:cool: :cool: :cool:
Old Jan 13, 2004 | 05:54 PM
david85's Avatar
david85
Default Re: Valve Cover Question (-=Persephone=-)
Thanks Jon.... Just kinda had my heart set on those darn flames. :mad Well mabe someday!
thanks again,
david
To Valve Cover Question
