optimal cooling temp and any suggestions
I did have about 1" of debrees( leaves) between the bottom of the rad and condensor which is now cleaned.
What do you guys feel the optimal operating temps are ? I have a 160 stat and was thinking of going to a 180 ?
[Modified by mike 1985, 2:35 PM 1/14/2004]
*I* vote to change the thermostat to a 180. You are already running hotter than that with the 160. The 160 just prolongs the warm up from the stat opening point to the evential running temp. The temps you have been running are GREAT, in my opinion. The 185 temp is on the lower end of the most desirable range.
One inch of debris between the rad and cond is minimal, but it's good you got rid of it. *I* would make sure there is no blockage in the rad, change to the 180 stat, reverse flush the whole system, fill with a good fresh 50/50 water antifreeeze mix, and pour in a bottle of Water Wetter. Be sure you get ALL the air out of the closed cooling system. You can wait on the Water Wetter, of you want to see if you need it and/or to prove to yourself how effective it really is. I think you're in good shape. Good luck, and...
RACE ON!!!
the replacement radiator is exactly the same as the otigional and appears to be in good shape. I'll go ahead with the new slightly bigger one and a 180 stat. I have just rebuilt the motor so all the coolant will be new and fresh. There was quite a bit of built up in the bottom of the block. I also went with the dart iron eagles, maybe the have better coolant passages than the stock heads, i don't know.
Mike
RACE ON!!!
RACE ON!!!
What other options do i have? Any one found a way to put a bigger 2-3 core rad in the car ?
What mods does the new engine have?
The problem with the 160 stat and the 160 fan switch, is if it does what is intended, your engine will run too cool. If it doesn't work, your fan will never shut off. Low temps are good for 1/4 mile blasts, but it doesn't do much to boil the condensation and contaminants out of your oil. For everyday driving your engine will be more efficient and last longer at closer to design temperaturers. FIRST, I would see if you have a problem. Don't forget the Water Wetter. Good luck, and..
RACE ON!!!
9.3-1
dart iron eagles ( 180 cc)
224-235 @.050 495-510 112 LSA
weiand stealth intake
750 demon.
2500 stall
i have a new stock pump, but i put a flow cooler plate on the back of the pump ( as advertised in jegs)
3.07 gear.
I think i'll try what i have and look into the rads to the left
[Modified by mike 1985, 3:40 PM 1/15/2004]
I'm still leaning toward the 180 stat in hopes that it will actually let the water stay in the rad and cool, as opposed to just circulating through.
Mike
Mike
Thermostats were created for two reasons: (1)To raise engine temperature quickly (2) To prevent the engine form OVERCOOLING. They have nothing to do with high end or overheating. If your home air conditioner was not cooling the house down, would you get a new thermostat? Of course not. The thermostat is telling to cool, it just can't.
http://www.dewitts.com/pages/categor...s.asp?catID=19
[Modified by Tom DeWitt, 10:58 AM 1/17/2004]
Tom,
Do you disapprove of Water Wetter? Or do you simply feel it's effects are minimal.
I like your home AC thermostat analogy.
For the record, do YOU have a range of temps that are best for our C4s for efficiency and longevity? About, how hot is too hot? Driving down the interstate, how cool is too cool? If you have the time, can you expand on the advantages/disadvantages of "overcooling"? Thanks, and...
RACE ON!!!
From my experience, you have to do any two of the following to keep your temperatures good: better WP, bigger Radiator, lower tstat, programmed fans in the chip. If you changed cams or are done with mods, then just have the chip reprog. to make the fan come on earlier and keep the 160 and you shouldnt have problems.
I would not mess with the radiator unless youre going to upgrade to a BeCool/Griffin/Davis-type larger radiator. Youre probably best off just upgrading the WP if you feel the need to do something.
The whole system is new so it should be working properly.
How can you test the sytem to see if it is holding pressure when you switch off?
Bob tells jack that Jerry drilled holes and he thinks it runs 10 degrees colder. Jack tells Tom to drill holes and it will run 20 degree cooler, and on it goes.
You have no idea how many myths I hear every day. Once a week someone with a cooling problem calls me for a new radiator and later I find out that a friend told them to run straight antifreeze and no water. Now I ask you, what car and what manual says this is a good idea?
Back to the home AC analogy. If the AC wasn't big enough and the unit was running continously, would you install a "bypass" wire around the thermostat? This bypass (holes) would make sure the unit running at full all ready would continue to run.
I've been accused on the forums of recommending a new radiator just to make a sale and I would never do that. Many times I have "unsold" a radiator after talking with the customer and finding the real problem. I think the thing to do with cooling problems is review the obvious stuff first. Make sure you have a 50/50 mix, the air path is not blocked, the instrumentation is working correctly and confirm these temps with an IR gun. All the seals are in place and the fans are working properly. If after all this has been done, then take a look at a new radiator. Don't waste your time with the tricks, there isn't one.
RACE ON!!!
[Modified by Tom DeWitt, 5:39 PM 1/17/2004]
Thanks for addressing my questions. I was particularly interested in your observations on "normal" temps. A lot of people on here advocate 160* thermostats for everyday use. As you noted in your home AC analogy, it won't make the engine run cooler. Some users comment that the engine runs hotter than 160, so the cooler stat does no harm. I contend that it prolongs warm up, and contributes to wear and tear on the engine. The other contingent likes having their engine run that cool. Like you said that isn't enough heat for effecient operation and boil-off of condensation and contaminents.
I respect the fact that WW does not have a necessary additive package. One of the classes I race in bi-weekly, does not allow antifreeze. Therefore, I run straight water in my daily driver during the racing season. What do you recommend for water pump lube and corrosion protection? My cooling system is stock.
RACE ON!!!
