Knock Retard Normal???
Old Jan 19, 2004 | 04:46 PM
C4Crazy787's Avatar
C4Crazy787
Default Knock Retard Normal???
I was reading in my How to Tune n Mod Chevy FI,
Quote: Because a slight amount fo ping is to be considered normal on applications equipped with ESC system, a reading of four or so should not be interpreted as a problem. pg. 103.
I have also read some where that the ECM will advance the timing untill it see's a knock.
My self and others have be chasing this perceived problem. I'm seeing upto 8* (peak) of knock retard above 4000rpm at WOT. I have tried octane boost and a retorque of the sensors to 12-14ft lb nojoy.
Is this normal??
I'm sure the CF knows :yesnod:
:seeya
Old Jan 19, 2004 | 04:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Knock Retard Normal??? (C4Crazy787)
The early L98s used the ESC module but not later ones; I don't think the LT1 uses it.
I was getting similar knock retard and Gordon Killebrew gave me the P/N of an "upgraded" ESC module. Installing it cured my false knock issues even with base timing at 8deg BTDC.
In your case you might try backing off base timing to see if knock retard is reduced. If not look for some cause of false knock; I believe you can also install the LT4 knock sensor to reduce sensitivity.
Old Jan 19, 2004 | 05:08 PM
6spd's Avatar
6spd
okay well it's good to hear that some is normal i'm getting no more than 5 degrees of retard but why is it happening at 3800 rpms you can feel the performance loss and it is supposed to make peak power at 4500-4800 rpm i'm dying out at 3800 thats were it starts????????????????
Old Jan 19, 2004 | 05:50 PM
6spd's Avatar
6spd
i found this Step 5----Same as above, except disconnected Knock Sensor due to false knock pick-up.
Step 5 results----1.70 60 foot, 12.42 @ 109 mph (Another victory, and again, my very 1st pass doing this I broke my previous best mph and et.... it was obvious, the knock sensor was reporting false knock to the ecm, perhaps caused by the harmonics of the headers or valvetrain chatter of the hyd roller cam. When the ecm reads falsely that the knock sensor is picking up false knock, it retards the timing anywhere from 2-8 degrees at wot... thus damaging performance when the retard was not necessary in reality. Everybody should think about trying this quick and simple test. {i have tpis headers with stage 8 bolts they have metal locking tabs that rattle thats one problem} 91 vette
Old Jan 19, 2004 | 05:55 PM
6spd's Avatar
6spd
when my friend was having the same problem as we are he had a custom prom done no more problem so what did they do to the chip???????
Old Jan 19, 2004 | 06:16 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: Knock Retard Normal??? (65Z01)
This can only be done with reprograming the prom I my case, Opti.
Could a bad lifter cause a false knock??
:lol: It figures, this is gonna cost me more $$ :smash:
:seeya
65Z01's Avatar
65Z01
Default Re: Knock Retard Normal??? (6spd)
If excess timing advance is the issue then reprogramming the chip would work; but if the knock sensor was "turned off" that is trouble waiting to happen.
If not excessive timing advance the problem must be in the sensor or some mechanical issue. You could try desensitizing the sensor and locating the cause of "clang".
Old Jan 19, 2004 | 06:19 PM
C4Crazy787's Avatar
C4Crazy787
They prolly adjusted the timing tables.
Old Jan 19, 2004 | 06:27 PM
C4Crazy787's Avatar
C4Crazy787
Yes, Yes, I want them to be able to detect detonation, but I dont think detonation is the problem.
I have suspected I have a bad lifter for a while now. This could be the root of the problem.
[Modified by C4Crazy787, 6:30 PM 1/19/2004]
Old Jan 19, 2004 | 09:38 PM
6spd's Avatar
6spd
i am going to try to put some teflon tape around it and see also you said i might be able to use the lt4 sensor?????
Old Jan 19, 2004 | 10:23 PM
C4Crazy787's Avatar
C4Crazy787
LT4 knock sensor/ module will not work on my LT1 or L98
http://forums.corvetteforum.com/zerothread?id=640484
Old Jan 19, 2004 | 10:47 PM
6spd's Avatar
6spd
what's up?? okay i think i no why it worked for my friend when i told you he got a chip from tpis 1 or 2 things it does make sense. when they made his chip they took some knock retard away with reprogramming or they moved the knock retard above his max rpm range this way he will get no retard from idle to lets say 4800 rpms after that retard comes in . it has to do with this if i'm saying it right i don't no all i know is i do have engine noise betwwen my headers valvetrain and injectors it is definitly false retard i read a post that said to detect false retard get some 100 octane put it in do wot if you get retard it is more than likely it's false but if it don;t it's mecanical
Old Jan 19, 2004 | 11:15 PM
C4Crazy787's Avatar
C4Crazy787
I found this link on desensitizing the kS, but I can't un-zip the download file. http://www.charm.net/~mchaney/f-tech.htm
Go search the word "knock" you'll find all kinds of stuff. I tried searching "knock retard" and got nothing. :seeya
Old Jan 19, 2004 | 11:56 PM
6spd's Avatar
6spd
type in false knock retard
To Knock Retard Normal???
