DUMB ECM QUESTION?
Old Jan 19, 2004 | 09:17 PM
redcorvettedave's Avatar
redcorvettedave
Default DUMB ECM QUESTION?
JUST A PASSING THOUGHT.......I HAVE A GRANATELLI MAF SENSOR THINKING ABOUT USING IT ON MY 94LT1 AS FOLLOWS.....PUT THAT PUPPY ON AND RUN IT FOR A WEEK OR TWO BEFORE THE ECM ADJUSTS TO THE INCREASE AIR FLOW ....I'LL JUST PULL THE BATTERY CABLE OFF FOR AWHILE AND JUST RESET THE ECM..AND START OVER AGAIN .......CAN I GET AWAY WITH THIS WITHOUT FRYING THE ECM. :conehead
Old Jan 19, 2004 | 09:36 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: DUMB ECM QUESTION? (redcorvettedave)
You're going to be best off, IMO, disconnecting the battery as you mentioned for 30+ minutes to reset the ECM, and then installing the Granatelli. Remember that the ECM has to relearn the entire RPM and load condition (though the LT1/LT4s go to the WOT table at low throttle settings), so it may take a little while for everything to shake out.
Old Jan 19, 2004 | 11:47 PM
southern vette91
Default Re: DUMB ECM QUESTION? (CorvetteZ51Racer)
when you changed the ecm did it change the miles on the odomenter back to 0 any one know how to modify this
Old Jan 20, 2004 | 04:54 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: DUMB ECM QUESTION? (southern vette91)
A few people know how this is done, getting them to tell you how, well :nono:
Old Jan 27, 2004 | 01:15 PM
southern vette91
Default Re: DUMB ECM QUESTION? (C4Crazy787)
i think you missunderstand i do not want to change my millage i have lowe millage now around 25000 but i think my ecm is going out i am have starting problem but its not in the starter if you tap on the ecm it starts i just want to change the millage if i buy a used one to what i have now let me know if you have any idea
Old Jan 27, 2004 | 02:47 PM
C4Crazy787's Avatar
C4Crazy787
:cheers: I think the mileage is stored in the MEM-CAL, this is allway's installed into the new/rebuilt ECM unless the mem-cal is the problem.
Call these guy's http://www.autoecms.com/ I'm sure they know.
:seeya
To DUMB ECM QUESTION?
