89 electronic air conditioning problem
Old Jan 19, 2004 | 11:47 PM
tomcat I's Avatar
tomcat I
2nd Gear
Default 89 electronic air conditioning problem
has anyone had this problem. when i call for heating all i get is cold air
temp valve actuator is not moving the door to the heater core.
could it be the programmer
thanks tomcat :
Old Jan 20, 2004 | 01:50 PM
ZylaRace's Avatar
ZylaRace
Default Re: 89 electronic air conditioning problem (tomcat I)
There is a good chance it is.
Remove the programmer and open it up. There are a couple high wattage resistors that develope cold solder joints over time. The easy fix is to reflow the solder. (Remelt the solder and let it cool.)
Reinstall and give it a try.
Also,.. dump (press a few buttons) the codes from the electronic unit. i.e. See what it say's.
Old Jan 20, 2004 | 02:05 PM
brookman's Avatar
brookman
can you see the actuator moving? Mine was stuck on full hot.
http://brookins.us/heater.jpg
the rod was just sliding in the plastic puck. I positioned it correctly and superglued it in place.
Old Jan 20, 2004 | 11:30 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: 89 electronic air conditioning problem (brookman)
Its the programmer.
Mine was stuck on hot
I just pulled mine last weekend.
One of the resistors had work it self looses.
Now I get hot and cold :D
Old Jan 20, 2004 | 11:39 PM
tomcat I's Avatar
tomcat I
2nd Gear
Default Re: 89 electronic air conditioning problem (Coupe89)
how hard was it to remove the programmer
thanks mike
Old Jan 21, 2004 | 12:26 AM
SunCr's Avatar
SunCr
Remove driver's side hush panel - programmer is above & to the right of the accelerator. It's approximately 3 X 5. Before careful removing the vacuum harness after you unbolt it. Before replacing, just make sure the linkage from the temperature door motor to the door is intact. It's on the passenger's side. Remove the passenger's side hush panel to access. There shouldn't be any play in it and as you or someone operates the controls, you should be able to see it move (If the motor is working). Also, is the outside temp light flashing? A bum motor or an open in the motor circuit may set a trouble code. To access, hold the ext temp button while pressing and releasing the auto button. Press warm until the display shows 08. Press the cool button and the trouble codes will be displayed: 00 - No Faults; 01 Air door feedback open; 02 Outside Temp Sensor open; 04 Outside Temp Sensor shorted; 08 Inside Temp Sensor open; 16 Inside Temp Sensor shorted. If you do replace the programmer, disconnect the battery to reset the memory in the dash panel and after you start it, there will be a delay while the panel learns the position of the door. The temp readout may also, momentarily, read -32.
Old Jan 21, 2004 | 12:29 AM
vette92_1's Avatar
vette92_1
Yours being an 89, I don't know if you have the same heater door motor that my 92 has but read this post, this is what happened to mine.
http://forums.corvetteforum.com/zerothread?id=729036
Old Jan 21, 2004 | 02:15 AM
Coupe89's Avatar
Coupe89
Default Re: 89 electronic air conditioning problem (vette92_1)
The only hard part about removing the programmer. Is the darn speed nut.
To 89 electronic air conditioning problem
