Power steering pump going bad?
Old Jan 20, 2004 | 06:02 PM
TPFKATK's Avatar
TPFKATK
Default Power steering pump going bad?
My ps pump is noisy like it's low on fluid when it's cold, fine when it warms up. I am guessing the pump is going out. Is the pump replacement as hard as it looks? Has anyone done the Caprice pump swap that is listed in the tech section? I am wondering about the part number or the specific year Caprice.
Harold
Old Jan 20, 2004 | 06:51 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Power steering pump going bad? (TPFKATK)
[QUOTE]My ps pump is noisy like it's low on fluid when it's cold, fine when it warms up. I am guessing the pump is going out. Is the pump replacement as hard as it looks? Has anyone done the Caprice pump swap that is listed in the tech section? I am wondering about the part number or the specific year Caprice.
:cheers: May i suggest a simple fix, that should work. Should work that is, unless you have already done it!
Remove your existing Power steering fluid and replace with a synthetic fluid! I use and have used Amzoil ATF fluid. ATF fluid is a hydraulic fluid!
I started having little steering glitches, including " morning sickness" 4 years ago and swithched to the ATF, no problems since.
Us the old battery syringe or your wife's turkey baster...remove the old fluid from the reservoir, refill with synthetic, run it and turn the wheels a few times!
Repeat above three times and see what happens
I think you will be pleased :D
:seeya
:steering:
[Modified by jackdaroofer, 6:55 PM 1/20/2004]
Old Jan 20, 2004 | 07:50 PM
C10 JDR's Avatar
C10 JDR
Lucas power steering stop leak has worked for many, including me.
Old Jan 21, 2004 | 12:59 PM
TPFKATK's Avatar
TPFKATK
Default Re: Power steering pump going bad? (britvette)
Jack I am going to try that. Nothing to loose! I don't think I can find Amsoil around here but I can find another top brand I am sure. Do you remember if you used Dextron rf do they even have different types in synthetic?
However, I have a hose leak too. If ATF is like motor oil, synthetic will make it worse. Have to bite the bullet and change the hose. That will be a good time to drain the fluid.
Harold
Old Jan 21, 2004 | 01:59 PM
dwestsr's Avatar
dwestsr
Amsoil can be ordered on line if you wish. They have a very extensive line of lube products and I have been please with the ones I use. :cheers:
To Power steering pump going bad?
