Oil Pan Question...
Old Jan 21, 2004 | 10:38 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Oil Pan Question...
I'm going to be swapping motors in my 'vette.
I have 2 options
the first is the '88 roller 350 from my Camaro
the second is a pre-86 block
Can I use the stock oil pan on either of those motors?
If not, what do I need?
Old Jan 21, 2004 | 10:45 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Oil Pan Question... (CarAteMyMoney)
I have 2 options
No, you'll need a different oil pan for the 2 blocks. The '88 Camaro block is a 1-piece rear main seal block, which has a different oil-pan than the pre-'86 block. If memory serves, the '86 is a 1-piece rear main block, so if you use the Camaro motor, you're good on the pan. If you use the older block, you need a different pan.
Old Jan 21, 2004 | 10:48 PM
CarAteMyMoney
Default Re: Oil Pan Question... (CorvetteZ51Racer)
what kind of pan should i get?
a generic replacement pan? or do corvettes take special pans?
Old Jan 21, 2004 | 11:16 PM
CorvetteZ51Racer
Corvette's have less ground clearance under the motor than most Chevy's. You're looking for a pan with a 7" deep sump. If you're looking aftermarket, Canton and Moroso both make 7" deep sump pans that will work. Canton lists theirs as a Vette pan, and they charge accordingly ($325 or so...rediculous for a wet sump pan), but it's a good pan.
Old Jan 22, 2004 | 12:04 AM
superlund's Avatar
superlund
The lowest price I know of on the Canton Corvette Road Race pan is $260, if that helps. Forum member "No Go" found that price, I gave like $290 directly thru Canton.
Old Jan 22, 2004 | 12:22 AM
CarAteMyMoney
Default Re: Oil Pan Question... (superlund)
Well, I wanted a roller cam anyway. Perfect excuse for a ZZ4 cam :lol:
Old Jan 22, 2004 | 11:14 AM
96GS#007's Avatar
96GS#007
I've installed a Canton Pan on mine while the car is down for cylinder head work. As Superlund alluded to, No Go found a place that has a decent price. Here's the link...
http://www.fullthrottleraceparts.com/index.htm
It's a very high quality pan. I did have to do some very minor trimming of the windage tray (it unbolts from the pan so not a big deal) to clear the oil pump & pickup. I wrestled with it for 3 hours over two days before doing that.
In addition to the pan, you have to buy a new oil pump pickup as well. Total for me for the pan, pickup, and shipping to St. Louis was ~$310
Old Jan 22, 2004 | 10:13 PM
CarAteMyMoney
Default Re: Oil Pan Question... (96GS#007)
i guess i might as well stick with the stock '86 pan and use it on the '88 motor, they should both be 1-pc rear main seal blocks
To Oil Pan Question...
