Why does my transmission....
Old Jan 22, 2004 | 12:27 AM
Perfusion's Avatar
Perfusion
Default Why does my transmission....
....grind sometimes when it's in reverse? I should mention that I've only noticed this when the transmission is cold, but that's sort of inherent I suppose, because that's generally when "reverse" is used - just after the car's been started! The 6-speed is much more "notchy", I've noticed, than other manuals out there, but my reverse gear is borderline ridiculous. Sometimes I feel like I literally have to fight it into gear, and there are times my wife can't even get it to go.
What gives?
:flag
Old Jan 22, 2004 | 12:38 AM
vette92_1's Avatar
vette92_1
Default Re: Why does my transmission.... (Perfusion)
I don't have 6spd, but it sounds like it could be the syncros. Maybe just a guess.
Old Jan 22, 2004 | 01:27 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Yes, let me first say my knowledge on transmission is extremely limited, so if this serves merely as a bump to the top. Let it.
On that note, I also have a weird grind just when cold when going into reverse. (Though on a 4+3 instead) I remember hearing that the reverse synchro was actually tied into the 1st gear synchro and thus that might be the cause of the problem. Hopefully someone will respond with a solid answer but maybe this can provide some insight. Good luck!
Old Jan 22, 2004 | 01:53 AM
GlockLT4's Avatar
GlockLT4
Default Re: Why does my transmission.... (USAsOnlyWay)
Sometimes i grind the gears in reverse... seems like it doesn't want to go. I think that it has so i start to let out the clutch and "wwhhhiiizzzz" ... push in the clutch and move the shifter real quick... Just hard to get it into reverse sometimes if the gears don't mesh just right.
Old Jan 22, 2004 | 02:46 AM
wake's Avatar
wake
Default Re: Why does my transmission.... (GlockLT4)
I did that once myself... Scared the hell out of me... :eek:
Old Jan 22, 2004 | 03:02 AM
USAsOnlyWay
Default Re: Why does my transmission.... (wake)
Yeah I know. Which is why now when I start up the car, I run the shifter in and out of 1st 3 times. And it slips right into reverse. Give it a try! :thumbs:
[Modified by USAsOnlyWay, 2:02 AM 1/22/2004]
Old Jan 22, 2004 | 06:53 AM
Atok's Avatar
Atok
:iagree:
I picked this habit up from driving a car that didn't have a syncro'd reverse gear.
Old Jan 22, 2004 | 09:28 PM
Perfusion's Avatar
Perfusion
I will! Thanks for the advice - I'll let you know tomorrow if it helps!
:flag
Old Jan 22, 2004 | 09:51 PM
Bobalooo's Avatar
Bobalooo
Hey, you might want to check the operation of the clutch. Fluid or may need adjustment. Just a thought.
Old Jan 22, 2004 | 11:20 PM
USAsOnlyWay
I hope it does help! :thumbs:
To Why does my transmission....
