Interior Lights Blinking, why?
Old Jan 22, 2004 | 09:42 AM
Red95's Avatar
Red95
Default Interior Lights Blinking, why?
All of my interior lights blink (go on and off). They do it every time I drive the car, sometimes more often then others.
I get in the car shut the door, wait for the lights to go off. Start the car, no problem, Foot on the brake, no problem, poopie to drive, no problem, start moving the car and the lights blink until I am up to about 20mph, they will then remain off for awhile but ocassionaly start blinking. :mad
When it is colder (20 degress) They will blink all the time. I have looked at the switches and they seem to work correctly when the car is sitting still. When I go over a bump in the road they will blink, sometimes but not always.
I am thinking I either have a bad switch or a problem in the ECM. How can I identify the problem?
Oh ya.... this is a 95, coupe, 105K miles.
Thanks in advance for any help.
Old Jan 22, 2004 | 10:09 AM
Dave C. '04 Z06's Avatar
Dave C. '04 Z06
Default Re: Interior Lights Blinking, why? (Red95)
My Corvette hasn't done it, but my Camaro did at one point. It turned out to be the hatch didn't close enough, so the light switch was intermittent. Mostly when the car bounced the light would flicker. I adjusted the switch and it solved the problem.
Hope this helps.
-Dave C.
PS: It could be a door switch also.
Old Jan 22, 2004 | 10:10 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
My first guess would be with one of the switches. Does the red "Door Ajar" light come (or blink) on when the lights flicker? If not I would start with the rear hatch switch. Mine used to do the same thing until I narrowed it down to this.
I beleive all I had to do was adjust it. If you take off the cover that sorrounds it you can see what I mean.
Good luck.
Eric
Dave C. '04 Z06
Default Re: Interior Lights Blinking, why? (Dave C. '97 Z28)
Oh yea...
You might be able to put some tape on the switch plungers, and then drive it to see which one it is? Good luck...
-Dave C.
Old Jan 22, 2004 | 10:16 AM
nonetooclose's Avatar
nonetooclose
:iagree: with all mentioned to this point, but another thing to consider is that you might have some loose wires on one of the switches and taping or further diagnosing the switch itself would not uncover the electrical gremlin.
I would recommend pulling the switches and examining them if you tested them with the tape method and had no luck.
Richard
Old Jan 22, 2004 | 11:00 AM
darkred91's Avatar
darkred91
Default Re: Interior Lights Blinking, why? (nonetooclose)
I had the same problum with my 91 I rolled up some paper and shut it in the doors one at a time to see if would stop blinking found it to be the passenger side door the switches my look ok but you need to check them..bet it's a door switch.
Old Jan 22, 2004 | 11:05 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
sounds like door switch or hatch switch... either adjustment needed, bad switch or bad wires.... :thumbs:
Old Jan 22, 2004 | 11:43 AM
Red95's Avatar
Red95
Thanks for all the suggestions. :D
I will test the hatch switch first. That was my first guess also. Then I will work my way to the door switches.
Now I hope it is the switch, not some wireing gremlin :crazy:
Old Jan 22, 2004 | 08:00 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Note that the door ajar light will not come on with the switch problem. I've been through two hatch switches already, I unplugged it for now since I don't feel like getting a third. You can unmplug the hatch switch and still have full capabilities as far as the alarm goes.
Watch this video, note how when the car flexes(such as through turns and stuff) that the interior lights will blink.
If your car is behaving as mine was, just unplug the hatch switch, if that works, you know you need to buy a new one, if not then the door switches are the culprit,
http://temp.corvetteforum.net/c4/mrmojo2//rt211u1a.wmv
[Modified by Mr Mojo, 8:02 PM 1/22/2004]
Old Jan 23, 2004 | 09:16 AM
Red95's Avatar
Red95
Default Re: Interior Lights Blinking, why? (Mr Mojo)
You guys were right.... the problem is the hatch switch. :thumbs: I have jammed some paper in the switch to make a solid contact and no problems. Even going out of the driveway no blinking. :D
Mr. Mojo, nice video. Looks like the Blue Ridge parkway.
This weekend I will adjust the switch, buy a new one or disconnect.
Thanks for everyones help. You guys are great. :hurray:
:hurray: :hurray:
Old Jan 23, 2004 | 09:31 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
I'm happy to hear you figured it out. Have a great weekend!:thumbs:
Eric
Old Jan 27, 2004 | 04:17 PM
fatboytm's Avatar
fatboytm
I had a similar problem on my 93. The lites would flicker on when i hit a bump or pulled into a driveway which made the car FLEX. I found out that it was my passenger door pin. I put a spacer behind the switch to make it extend out further. No more problem.
To Interior Lights Blinking, why?
