84 - won't idle, no codes - HELP
RACE ON!!!
ECMs should be available at an auto parts store. They are sold as, "rebuilt, exchange". I am not familiar with their cost. You can do a "Wanted to Buy" in the C4 parts section. I have seen them for sale, from time to time. You should also try the "Crossfire Vault" www.crossfire.homeip.net/. A lot of those guys have converted over to later, faster ECMs. Some may have their old ECMs, for cheap. Good luck, and...
RACE ON!!!
If you do need a new ECM and you decide to convert over to the 7747 then you will need to be prepared to make a prom. I have a 7747 and a Prominator and I am in the process of tuning my setup now. Unfortunately there are not any 7747 prom's for stock 84s. I am just running a ported crossfire manifold and 1.6 rockers which required a new prom to get it to run right.
Checkout the Crossfire Vault - the folks there are quite knowledgable and may be able to help you better than I can. It is worth registration and a post or two.
