HELP!!!!!!!!
Old Jan 22, 2004 | 05:42 PM
skidfive's Avatar
skidfive
7th Gear
Default HELP!!!!!!!!
well, we just got the new battery for my 87 corvette, and we connect it and we start to hear a buzzing. it sounds like it is coming from the drivers side of the rear spare tire. We thought it was the fuel pump so we put some gas in, put the battery back in and it still goes. even when the car is off, just the battery connected. I dont know what it is, can you help.
Also, when the battery is connected the lights on the inside wont go off, the ones on the doors.
thanks in advance
Old Jan 22, 2004 | 05:47 PM
bogus's Avatar
bogus
Default Re: HELP!!!!!!!! (skidfive)
ABS pump?
make sure the battery connections are solid and not corroded or worn.
Old Jan 22, 2004 | 05:51 PM
scorp508's Avatar
scorp508
Default Re: HELP!!!!!!!! (bogus)
The only things "buzzable" in that area would be the fuel pump and ABS pump. Throw a fuel pressure gauge on it and see if somebody hotwired the fuel pump. Or perhaps the fuel pump relay is stuck on.
Old Jan 22, 2004 | 06:00 PM
1MoorTym's Avatar
1MoorTym
power antenna
Old Jan 22, 2004 | 06:08 PM
skidfive's Avatar
skidfive
7th Gear
Default Re: HELP!!!!!!!! (1MoorTym)
im pretty sure it is the power antenna, it is stuck up, and isnt going down
Old Jan 22, 2004 | 06:25 PM
TheStef's Avatar
TheStef
This is going to sound a bit harsh.. but force it down wile you have the battery connected and wile its making the busing sound.
I can't promise it will want to come back up though, but at least the buzing will stop and then you can look into replacing the motor.
Mine sometimes won't go down, but it doesn't make any buzing sound... I just push it down a bit and it goes back down.
It normaly always come back up when I turn on the radio though witch is why I don't really care for changing the motor yet.
Hope this helps!
Old Jan 22, 2004 | 06:27 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:thumbs:
Old Jan 23, 2004 | 01:19 AM
86Moon's Avatar
86Moon
If the antenna doesn't want to go down you can remove the carpet by the rear hatch latch and there is an electrical connector there you can unplug for the power to the motor.
Welcome to the forum! :cheers:
Old Jan 23, 2004 | 08:59 AM
Unriced's Avatar
Unriced
________________________________________ ______________________________
The door lights can be pushed like switches....they even say "push" on them..
Maybe your door lights have been switched on?
To HELP!!!!!!!!
