Rear wheel bearing installation
Old Jan 23, 2004 | 04:16 PM
kohlbear's Avatar
kohlbear
Default Rear wheel bearing installation
Anyone know directions for changing the rear wheel bearing on an 87 Z52? :chevy
Old Jan 23, 2004 | 09:58 PM
sraft's Avatar
sraft
Default Re: Rear wheel bearing installation (kohlbear)
You'll need a 36mm socket for the spindle nut and a torx-55 for the hub bolts. Removal of the halfshaft will give you more space to work with, but is not a must. Tighten the spindle nut back to the proper torque. Search the archives - this subject has been beaten to death.
Old Jan 23, 2004 | 10:06 PM
chucks88's Avatar
chucks88
Default Re: Rear wheel bearing installation (sraft)
I didn't have to remove parts in order to do it. You'll have to get your rear up kinda high to be able to get any leverage to break the 3 T-55 bolts. In fact I would spray those puppies. Mine were a biotch to get out.
Old Jan 24, 2004 | 12:32 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If I remember correctly, I only removed the caliper. And as stated earlier, get it up high as leverage is king.
3/4" impact didn't faze the axle nut= 6 feet of pipe did
1/2" impact didn't faze the torx bolts=16 inches of pipe did
This job requires grinding your teeth, so put the mouth guard in now :jester
Old Jan 24, 2004 | 12:37 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Rear wheel bearing installation (AGENT 86)
Thats one hell of a breaker bar (6') - the 16" i can understand.... :eek:
Old Jan 24, 2004 | 12:42 AM
AGENT 86's Avatar
AGENT 86
Default Re: Rear wheel bearing installation (vinnies87)
Yeah, and I bent that 6 footer loosenig the axle nut :eek:
Old Jan 24, 2004 | 12:11 PM
sraft's Avatar
sraft
Default Re: Rear wheel bearing installation (chucks88)
...... You'll have to get your rear up kinda high to be able to get any leverage to break the 3 T-55 bolts......
:iagree: that was the hardest part of the job. It's easier if you have an assorment of extensions and universal (swivel) adapters - I had to keep trying different combinations of tools until I hit upon one that fit and also gave the leverage to break the bolts loose.
Old Jan 24, 2004 | 01:22 PM
scorp508's Avatar
scorp508
What kind of pathetic impact wrenches are those? :jester The Torx are only 65 ft/lb while the 36mm is 3 times that. My 1/2" impact buzzes the 36mm off like nobody's business.
You'll also need a new cotter pin to replace the one that is over the spindle nut. The brake caliper I think is two 19mm bolts. You may also need a rubber mallet to get the brake rotor off if it hasn't been off in a long time.
To Rear wheel bearing installation
