slow to start?
Old Jan 23, 2004 | 04:17 PM
dwestsr's Avatar
dwestsr
Default slow to start?
I wouldn't say that my 86 has a hard start problem, but It does spin over more that it should before catching. Also , It doesn't matter if it is hot or cold.
I had a leaking injector and had them all cleaned and flowed by Rich @ cruisin performance. I have also done the following: New cap, wires, plugs, rotor, cleaned TB , new IAC, set tps volts to 0.54. The car idles as it should @ 700 rpm but it is very slightly rough. I checked compression while changing valve seals and it's OK. I hear the Fuel pump come on as it is supposed to for ~2 seconds when the ignition is turned on. I can crank it up, shut it down and restart with exactly the same result . So I don't think it is fuel pressure. Fuel pressure leak down is OK.
Despite all of this , that %$#&^% motor is determined to spin over for about two seconds no matter what I do. Car runs great otherwise. Anybody want to take a crack at this one? :cheers:
Old Jan 23, 2004 | 04:37 PM
CaliforniaVette's Avatar
CaliforniaVette
Default Re: slow to start? (dwestsr)
whenever i deal with a slow starting engine... first thing i always check is the battery. take it down to your local shop and have them do a load test. How old is your battery? have you ever maintained it? usually slow starts can be associated with weak batteries. If your battery checks out fine next thing i would look at is the starter. Its a possibility theres to much resistance, you would have to do a starter draw test. any shop can do these test for you. Causes of high resistance are heat, long/damaged cables, corrosion. so check all your starting system connections and clean/service if nessecary. As far as your idle, i would check you IACV (idle air control valve) after the most basic things are ruled out then i would start checking fuel.. in your case i highly doubt thats the problem
hope this helps... good luck
[Modified by CaliforniaVette, 9:40 PM 1/23/2004]
Old Jan 23, 2004 | 05:14 PM
dwestsr's Avatar
dwestsr
Default Re: slow to start? (CaliforniaVette)
New starter & new battery. It turns over very fast. Problem is not starter related. Sorry if my post sounded like it wasn't turning over fast enough , but it is.
Old Jan 23, 2004 | 07:40 PM
CaliforniaVette
new question, when you replaced the battery and starter. did it start how you wanted it to? or was it still reluctent?
Old Jan 23, 2004 | 08:55 PM
dwestsr's Avatar
dwestsr
Starter and battery had no impact. Thanks
Old Jan 25, 2004 | 01:50 PM
lspalding's Avatar
lspalding
ttt
Have identical issues with '89, still unsolved. In addition to your items, have also tried different MAF and changed the oil pressure sender. Anybody?
Old Jan 25, 2004 | 04:50 PM
86VetteBill's Avatar
86VetteBill
Default Re: slow to start? (lspalding)
I'll jump on this bandwagon too. My '86 starts very well when it's really cold out. But, after it's running and I do a re-start, I'll get a 'good-speed' cranking for about 2-3 second spin before the engine starts up. And, as with dwestsr, same idle characteristics, TPS checked out. I put in a new IAC a couple months ago with no change.
I was searching and found someone post that the 450 base idle was raised to 550 in a Sevice Bulletin. Can anyone back that up? I could go out there and try to re-set to 550 rpm, TPS @ .54, WOT @ 4.65....
Trying to help solve this annoyance.
Bill
To slow to start?
