valve cover modifications
Old Jan 24, 2004 | 08:31 AM
9T3JIM's Avatar
9T3JIM
Default valve cover modifications
Since the search option is DOA does anybody have pictures of drip tab removal for roller rockers? I remember seeing some a couple months ago, but can't remember who posted them. TIA
Old Jan 24, 2004 | 08:59 AM
h rocks's Avatar
h rocks
Default Re: valve cover modifications (9T3JIM)
You can just get a pair of pliers and break them off, or you can take air grinder or Dremel tool and remove them. Not brain surgery, and hard to screw up.
Old Jan 24, 2004 | 09:03 AM
RichS's Avatar
RichS
Default Re: valve cover modifications (h rocks)
:iagree: With my 95 I just snapped them off then smoothed them out with a dremmel.
Old Jan 24, 2004 | 10:37 AM
atotalnincompoop's Avatar
atotalnincompoop
dremel :yesnod: :thumbs:
Old Jan 24, 2004 | 01:39 PM
JasonL's Avatar
JasonL
Default Re: valve cover modifications (atotalnincompoop)
http://www2.hawaii.edu/~wilsonch/lt4valvecover2.htm
Old Jan 24, 2004 | 01:41 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I ground mine down by about 2/3 with a Dremel and have no clearance problems with my bulky, aluminum, full rollers.
Old Jan 24, 2004 | 06:53 PM
Strick's Avatar
Strick
I used a dremel tool with a small cutting wheel. Good clean cut. :thumbs:
Old Jan 25, 2004 | 03:59 PM
88_vette's Avatar
88_vette
Default Re: valve cover modifications (Strick)
Dremel as mentioned above. Cut a little slit in the tabs then break them off with pliers. Don't just tryt o rip them out with pliers. I've heard stories that this can break the vavle cover leaving you with a hole in it.
Old Jan 26, 2004 | 12:04 AM
JAKE's Avatar
JAKE
Default Re: valve cover modifications (88_vette)
Yep, happened to me when I tried breaking them off. A dab of silicone sealant filled the hole.
Jake
To valve cover modifications
