4+3 Shift shaft seals replacement
Old Jan 24, 2004 | 04:59 PM
LD85's Avatar
LD85
Default 4+3 Shift shaft seals replacement
Well Scorp said it was easy so I said what the heck...
I had small drops of oil coming out of the two shift shaft seals on the 4+3 side cover,, so I took the side cover off and pressed two new seals in, cost @ $8.00 for two seals at NAPA or AUTOZONE.
This is what the side cover looks like on the back side.
:smash: :thumbs:
Old Jan 24, 2004 | 05:05 PM
scorp508's Avatar
scorp508
Default Re: 4+3 Shift shaft seals replacement (ld85)
Nice work. :) Now through a new cover seal on. Just don't let the little spring and ball bearings fly out from the middle there. :D
Old Jan 24, 2004 | 09:54 PM
LD85's Avatar
LD85
Default Re: 4+3 Shift shaft seals replacement (scorp508)
Done! All back together, new seals and gaskset so baby will have a dry bottom! Simple project for sure! :seeya :thumbs:
Old Jan 24, 2004 | 11:06 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
:cool: Although my leaks are coming from the damn gear switches. RTV hasn't helped. :banghead:
To 4+3 Shift shaft seals replacement
